Bare 4x4 head + bits
Old Jun 8, 2005 | 08:20 PM
cossie550+'s Avatar
cossie550+
Default Bare 4x4 head + bits
completely bare, no caps or valves do have springs, 138.7mm, 110 pounds,
also have:
4x4 throttle housing, bare 30pounds delivered,
standard 2wd inlet cam 25 pounds delivered,
2wd sump no baffel plate, 15 pounds,
2x 2wd fuel regs, 15 pounds each,
2x 2wd plenum covers, 15 pounds each,
cheers john. 07795 331079
Old Jun 8, 2005 | 10:12 PM
Damo V's Avatar
Damo V
No cam caps??
Old Jun 9, 2005 | 06:46 PM
cossie550+'s Avatar
cossie550+
"completely bare, no caps or valves", cheers
Old Jun 10, 2005 | 11:21 AM
PGT's Avatar
PGT
for what reason would someone remove the valves and other stuff if the head casting itself is ok. i might be interested if you know the state of the casting.
cheers
Old Jun 10, 2005 | 07:07 PM
The DIVA's Avatar
The DIVA
The head is scrap without the cam caps mate as they are line bored making them unique to that head....
What happened to em,you can`t use em on another head.........
Old Jun 10, 2005 | 08:56 PM
cossie550+'s Avatar
cossie550+
its an old head thats been sat in a mates garage for ages, casting is ok but missing the parts i have already mentioned Ta.
Old Jun 11, 2005 | 12:26 PM
PGT's Avatar
PGT
dont agree that its scrap.
even though the head may be line bored, when you actually fit the cams in to a head you will see that there is no dowelling to locate the caps anyway.
further, the stud holes on the caps are 8mm and 8.5mm so the stud going through the 8.5mm stud cap hole allows for a large amount of movement which would surely render the line boring irrelevant in terms of cap location.
what the line boring does ensure however, is that a perfect semi circle exists in the head casting and another one in the cap. when you tighten the caps down with a cam shaft fitted, and considering the spring pressure trying to force the cam against the caps, it looks like the cam is used to locate the caps!
on that basis you could for example overdrill the 8mm stud hole on any cap and use it on any head in the knowledge that it would be located by the cam as the cam settled into its perfect semicircular bearings in the head.
still better to have the originals of course and diffcult to see anyone payiny waht you are asking.
pm me if you will take less
Old Jun 11, 2005 | 12:31 PM
dave cos4x4's Avatar
dave cos4x4
thats very cheap if its not a scrap head.
Dave.
Old Jun 11, 2005 | 12:58 PM
PGT's Avatar
PGT
not really. you still need all the other bits to be able to use it. in fact you need another 'scrap head'
Old Jun 11, 2005 | 02:45 PM
dave cos4x4
i have all the bits you need from my head except cam caps.
Dave.
Old Jun 11, 2005 | 04:45 PM
PGT's Avatar
PGT
i think i'd need to know why the head has no stuff in it first - cracked/warped?
Old Jun 12, 2005 | 07:03 PM
cossie550+'s Avatar
cossie550+
100 quid, bits were removed due to being used on another head apparantly, don't mind anyone having it checked first
turbotrev
Aug 22, 2015 11:41 AM
IAN RS2k
Aug 18, 2015 07:51 PM
ekjim
Aug 17, 2015 08:57 PM
Old ford
Jul 31, 2015 06:50 AM
