Cone filter on saph cossie.
Got me new cone filter today for my saph cossie and need to know what do i do with the two pipes that are attached to the old airbox,do i just blank them off or vent them to the atmosphere ?
I think the thick one is a return from the breather system, dont blank that off - cable tie an empty open fanta* bottle to something and stick it in there. The thin one comes from the amal valve and i think its ok to remove it, with at the amal valve or just leave it disconnected.
*if you really don't like fanta, you may be able to get away with a coke bottle.
the small one to the amal valve can be removed. the larger one comes from the crankcase vent. u should get a small filter & attach it to this beside the inlet manifold. easy to sort.
before i had my bailey mirror image tank i had my oil breather hose conected to a little bottle..it looks teribble...you have to put some holes in the bottle to...
the other one which leads to the amalvalve you can trow it in the bin...
now its this...
now its this...
Originally Posted by ksa74f/231bhp
Like the look of that m8,what a difference with the cone filter on chatters like a biych now.
but i can close the dv so it could chatter...
Johnny Knoxville
Sep 30, 2015 07:21 AM
