Rattling & Clicking = ABS light on ??????
Old Jun 7, 2005 | 11:14 AM
220TC's Avatar
220TC
Default Rattling & Clicking = ABS light on ??????
Hi,
This morning when I started up the car I noticed a loudish rattling & clocking noise from behind the dash somewhere, I just assumed it was plastic vibrating or something ! I then noticed the ABS light was flickering as well at the same time , the noise then stopped and ever since then the ABS light has stayed on, anyone know what it could be, relay etc.. Car is a series 2 erst by the way.
cheers, Duncan
Old Jun 7, 2005 | 11:17 AM
rsnissan's Avatar
rsnissan
sounds like a dodgy/loose live to the relay turning it on and off quickley
Old Jun 7, 2005 | 11:22 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Our 2wd cossie does that too when coasting to a stop and breaking
Old Jun 7, 2005 | 11:51 AM
220TC's Avatar
220TC
anyone know where the relay is exactly that controls the ABS light on the series 2 erst's ?
Duncan
Old Jun 7, 2005 | 07:56 PM
220TC's Avatar
220TC
anyone ?
Old Jun 7, 2005 | 07:59 PM
dave green's Avatar
dave green
All the ABS light tells you on a S2 rst is that the ABS belt has brocken
Dave.
Old Jun 7, 2005 | 08:19 PM
GUZZLER's Avatar
GUZZLER
if its rattling its probably a loose modulator. they are on the other end of the abs belt.
Old Jun 7, 2005 | 08:33 PM
220TC's Avatar
220TC
Im pretty sure the rattling & clicking sound was coming from behind the dash, the light was flickering as well and then when the noise stopped the light stayed on
Old Jun 9, 2005 | 06:22 PM
dave green's Avatar
dave green
There is no ABS relay on a S2 RST
Old Jun 9, 2005 | 06:26 PM
220TC's Avatar
220TC
could an electrical fault somewhere behind the dash cause the light to flicker and then stay on constantly, if so what
Old Jun 9, 2005 | 06:36 PM
S2Dan's Avatar
S2Dan
The exact same thing happened to mine mate. I know that noise you mean, i was blasting down the motor way when my ABS light started to flicker, i shit my pants, thinking that the belts had snapped However after a close look the belts were fine. I have always assumed that it must be one of the switches which plug into the belt cases which were faulty. I plan on replacing both switches, don't think the switch assembly costs that much either from ford, worth doing if the ABS light is doing ya nut in.
Old Jun 9, 2005 | 06:46 PM
220TC's Avatar
220TC
the cars up for sale at the moment so I've got to sort it out really, cheers for the info mate, I'll look into it
Old Jun 9, 2005 | 06:49 PM
Oranoco's Avatar
Oranoco
Whip the sensors out and zippie the switches closed. Job jobbed
If the belt is slightly loose it can do this. Undo the bolts with a 13mm socket and rotate the modulator to increase the tension on the belt. Don't make the belt too tight
cossiestu
Sep 19, 2015 05:19 AM
Flatlinedan
Sep 18, 2015 12:41 PM
The Enigma
Sep 12, 2015 10:12 PM
fuzzy
Sep 4, 2015 10:11 PM
