Yup. All bearings replaced & all seals. From a local mechanic/ metal engineer/ gearbox builder who has worked on & owned fast Fords for around 40 years. Owned all the RS's bar the Focus. Currently got an RS500 & Esco Cos...and is good friends with Graham Goode. Can build it to whatever spec you want..as long as it's possible.
Was done in about 3 days inbetween other jobs as I was in no rush for it.
Got a number for him Shawn as mine is startin to show signs of replacement. Starting to slip out of gear and speedo not workin. Had everything checked and the problem is in the box. It's done 86k so not done too bad. Engine rebuilt 2k ago by previous owner but box not done.
theres a rolling road aswell now £30 in advance or £40 on the day you fancy it if im on the road i think its coming out in about half n hour any way so gonna pull it in bits and have a look mate says he knows how to rebuid them
