fuel pump
Fixed me motor today turned it over for a while then connect everything up ready to fire the ole girl up and nothing just sat there turning over! cecked the plugs and they were bone dry!
couldnt hear the fuel pump at all! arse!
any tips on changing the fuel pump without looseing the half tank of optimax i got!
cheers
cheers
Fuel Pump relay gone tits up?
Pinky/purple one under driver side dash - they do melt and will fail
Regards to the pump itself, get a pair of clamps and close the hose just before it gets to pump
Other thing worth doing, put some new connections on the fuel pump, I do mine every year as they only go rusty/corrode and cause all sorts of issues
Test things before assuming they are fucked mate! Saves repairs getting expensive. Have you checked the fuse? The pink relay sometimes fails but these can be repaired if you know how.
Under your drivers side dash, will be 3 relay's located on a row of clips
Easy to find, just make sure it goes back in the clip properly or it'll cause loose connections and burn then eventually die
which it may have already done!
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
