What cam are plp using?
Davie, all well being saying use Newman, but does anyone actually give us info about them
It's been suggested before they're good, but for god's sake tell us about them!!
newman kent are of a shite quality piper r ok but newman will out last both i've got a custom newman cam
they do an off the shelf cam for the 1600cvh phone them up for cam spec speak to ken newman
Cheers lads
I have a kent cam but its worn at only 10k..was thinking a piper t2 with double valve springs and anti pump lifters...
The newman cam sounds ok from what plp have said but abit on the pricey side..as he said you can only use the solid lifters with it..which means buying a clamping tool etc aswell.
Anyone fitted the newman solid lifters there selfs? what are they like for adjusting?
Originally Posted by rs_daz
Cheers lads
they come with a lock nut and a bolt in the middle of them, you have to turn the screw until you have the Desired clearance and then take it out and lock the follower in the clamp to tighten the nut.takes a while to get it right 8-10 inlet 10-12 exhaust
Std Ford one right now, been in the engine for 8 years since Mark Shead built it - yeah it's fooked now and you should see my RR graph to see how I know this ROFL!!
Mc5506
Oct 5, 2015 09:57 PM
