Pace Charge Cooler Fitting
just a quickie who has one....and where did you mount the pump and header tank?
Got no idea where to put them have been fucking around for hours now trying to find somewhere but im at a total loss
only place i can find is pump behind headlight secured with zip ties and tank in small gap between metering unit and fuel filter.
would like to see some other installs if poss!
i hadone mate put header tank on the black plastic thing aroud the heater matrix, pump in same place as you have, should of said mate i'd have come over and given you a hand
cheers lads
Seb, cheers for the offer mate i will do next time
Mike, wheres the header tank in there and how have you secured the pump as thats the same kinda place mines trying to be!!!
and lastly down by the gearbox sounds pretty good actually, will have a lookie!
rich see on that pic above, the little bit that sticks out on the matrix shroud right by the strut brace on the right, that where i screwed mine on, the pump was roughly the same place had to take the wheel off and arch liner to nut and bolt it
would have to agree with t28rst,charge coolers dont work very well.a good intercooler is much better,but when i had one i mounted my pump on gearbox too,it helps keep pump cooler aswell.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
