After 2 years i can't get it to start
after 2 ish years doing the under side i just try'd to start it with no luck, i've took the main fuel line going in to the meter head and none is getting through?????????????????????????also the pump is loud, could it be the pump wires are the wrong way round ?? or does it not matter ????
mark
i wouldnt be suprised if the pump is goosed...last time mine went it would buzz when priming, and when wired constant...wasn't pumping any fuel thru tho...to be sure, take the pipe off the m'head or accumulator, shove it in a jiffy can or whatever and run the pump...see what comes out
HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i've looped the pump and undone the 4 injectors at the meter head then push the flap down and let it pump for 5 mins and NOTHING ????????? not a drop of fuel wtf is going on ??????
is there anything i could have put back wrong ???????????
mark
mark
i tested my pump like that..then hooked up the pump to a battery and nothing! didnt do a thing...tho mine didnt buzz either....you sure u got no leaks,bends or blocks?
do you have a way to another pump?
steerfromdarear
28
Jan 29, 2016 06:14 PM
rog
Sep 4, 2015 12:10 PM
The Enigma
13
Aug 20, 2015 09:38 PM
