Why it still leaking!
Tried 2 cork rocker gaskets and today fitted the rubber gasket from the 1.8 CVH sierra and it still leaks at the front left and the side by the cam pulley
1.8CVH
fuck cork gaskets, get a rubber one which is supposedly off a 1.8cvh sierra. ! cork ones are wank.
*edit*
i'll try reading the full post now
is it DEFFO the gasket leaking and not the cam seal?
are the bolts tightening up fully and is the surface the gasket sits on the head clean/flat? is the rocker cover bent ?
*edit*
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
