S1 advice
Colour t-cut shouldn't change the colour of the car: does pink polish turn it pink, or normal brown t-cut change it ? No t-cut or colour-polish is ever the right shade for the car anyway.
All it will do is lift off any in-grained dirt & make it shinier & cleaner looking. Go for it.
If you are that bothered about it possibly changing the colour, do a test on the slam panel, or inside the boot first to check.
I suppose it depends on how badly the colour has changed, mainly sun-fade probably.
does the paint look faded at all? If it's been looked after & polished regularly before you got it, then it may be ok..but if you're unsure, do the test piece first & see how it looks. If the slam panel, or wing-top edges under the bonnet look the same as the wing, then the colour won't have changed that much.
Good luck on the polishing, it's nice weather for it.
vroooom ptssssh I think the colour is ok myself but wanted to spend a good few hours makin her look as new. Thought i could use something to bring the paintwork to as it was. If it makes a difference then fine, if not then. . . . fine again ! Wanted to know wot would be the best stuff to use.
It can be, but like I put on the last post mate, if it's quite badly faded then it wil bring it up. If it's been looked after & isn't too bad (the slam panel - wing check) then it may not need t-cutting.
mk3ste
Oct 17, 2021 10:09 AM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
