Rebuild Day has arrived!
May 28, 2005 | 04:53 PM
Finally the day has arrived for my car to be passed on to Stu at MSD to let him work his magic!
Work to be done:
Full standard engine rebuild to low compression (Mahle pistons, etc)
Alcon 6 Paddle clutch
Pro alloy Intercooler
Samcos all round
Also gave him a shiny new Stage 2 Turbo from T Technics to run 20psi
Now comes the hardest part, to wait for it!
Mark
May 28, 2005 | 05:28 PM
cool mate
i had my car chipped there.
spot on job to, gave some good advice
it will be a minter when you get it back
May 28, 2005 | 06:03 PM
Quote:
Originally Posted by bzd32
cool mate
Yep, I had it first set up when I got it by MSD, and made a real difference (especially for only Ł100!) only downside that day was almost ripping the exhaust completely off on that bloody speed bump going into the industrial estate!
May 28, 2005 | 06:26 PM
if u dont mind me asking mate, how much is that work setting u back ?
May 28, 2005 | 06:55 PM
Quote:
Over Ł3500!
May 28, 2005 | 07:24 PM
May 28, 2005 | 07:29 PM
I'll tell you when its done!
May 28, 2005 | 07:30 PM
May 28, 2005 | 07:36 PM
so thats about Ł2600 for the rebuild? Ł2600 for a low comp build is good! stu only uses top quality stuff!
will be one hell of an engine!
best of luck with it!
May 28, 2005 | 07:40 PM
Quote:
Originally Posted by james_birch
so thats about Ł2600 for the rebuild? Ł2600 for a low comp build is good! Stu only uses top quality stuff!
Yep thats about right, the turbo was Ł600, intercooler Ł300, clutch Ł400 samcos about Ł400, don't half add up after a bit!
p.s. James - the dump valves being removed
May 28, 2005 | 08:09 PM
Quote:
good man!
May 29, 2005 | 06:13 PM
i know wot you mean about the speed bumps bbsheppo
ouch
May 31, 2005 | 05:14 PM
my rebuild has cost 6k so far, and not finished yet
May 31, 2005 | 06:07 PM
Quote:
nutter!.....cossie cossie! lol...best of luck with it! got that 5th on yet?
May 31, 2005 | 06:39 PM
booked in to get fitted on the 8th, 230bhp here we come
May 31, 2005 | 07:48 PM
at least!
May 31, 2005 | 08:30 PM
Stu at MSD certainly knows his stuff, i only have mine set up there...
standard engine, turbo, cam etc, 198bhp at 16psi with pro-alloy intercooler
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
TPM961
Jan 15, 2018 10:50 AM
`spotty
Sep 25, 2015 11:41 PM
coscor86
Sep 20, 2015 01:21 PM
mattxr3i
Sep 13, 2015 05:52 PM
