4x4 L8 Stage 3 Chip For Sale - PRICE REDUCED TO CLEAR!!!!!!!
Old May 28, 2005 | 07:20 AM
Graceland's Avatar
Graceland
Team HOTHOT!
Default 4x4 L8 Stage 3 Chip For Sale - PRICE REDUCED TO CLEAR!!!!!!!
Stage 3 chip for an L8 ECU 4x4 Cossie.
Setup to run standard engine mechanically, dark green (803) injectors, 3 bar map sensor and -31 actuator and 22psi.
Manufacturer is Interpro and comes on a liccle board ready to plug in - this has been sat in my cossie since 1995 according to the installation date and the engine is the original - only selling due to upgrading to new software/chip from MSD.
I have it on good authority that this chip is a Superchips item that retails at £lots
As with purchasing ANY aftermarket chip, it is reccomended to take the car to a REPUTABLE tuner - such as Stu @ MSD, Karl Norris etc etc, for them to check the onload boost and fueling and ignition.
======DISCLAIMER======
I will NOT be held responsible if your engine melts a piston due to inadequate setting up, or you crash your car while the dog jumps onto your lap and eats your face.
Looking for around £65 ono for this item
PM Me if you are interested.
Old May 28, 2005 | 10:14 AM
Graceland's Avatar
Graceland
Team HOTHOT!
note - will swap for a 4x4 cosworth inlet plenum/manifold assembly (i don't need the throttle body, just the plemun and manifold)
Old May 28, 2005 | 10:15 AM
The DIVA's Avatar
The DIVA
Old Jun 12, 2005 | 04:29 PM
Graceland's Avatar
Graceland
Team HOTHOT!
:bttt:
£reduced to £50 including postage
Old Jun 25, 2005 | 11:35 PM
ped's Avatar
ped
still for sale i want it
Old Jun 25, 2005 | 11:37 PM
ped's Avatar
ped
will work in esc cos ?
Old Jun 26, 2005 | 12:16 AM
Graceland's Avatar
Graceland
Team HOTHOT!
it is for sale.
it will work in any cosworth with an L8 ecu - this means it will not work in L1, L6 or P8.
ONLY L8
Old Jun 27, 2005 | 04:27 PM
Dicko&Vacant's Avatar
Dicko&Vacant
pm sent mate
dicko
Old Jun 27, 2005 | 07:22 PM
Graceland's Avatar
Graceland
Team HOTHOT!
replied with my number for your mate to ring.
jason_nike
Aug 18, 2019 10:53 AM
big_Rad
Sep 15, 2017 09:36 AM
JasonPD
21
Aug 20, 2015 07:36 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
Old ford
Jul 31, 2015 06:50 AM
