2WD cossy for breaking
Full set of red Samco boost and water hoses provisionally sold
Motor £1000
Scorpion Stainless 3" system £200 as new condition
Standard wheels in good condition £125 for 5 with tyres
cloth interior (very tidy) £185 very clean no bolster wear
front and bumpers £65 and £50
gearbox £200 provisionally sold
rear diff £140
brakes front £85 pair
rear brakes £85 pair
boot lid in Flint grey £85 VGC
Prop £75
altenator £45
Starter £40
3 Doors VGC with electrics £100 in Flint drivers need repair
Inlet manifold complete (yellows) £125
Exhaust manifold £50
T3 Turbo, no wear £125
HT leads £20
Rad and fans £75
2WD intercooler £35
K&N filter cone type £45
Dump Valve £35
Power Steering pump and resevoir £40
ECU £100
Clear indicators front £10 pair
Rear tinted lights and surround £35
Dash £35
Clocks £35
Fuel Pump and cage £45
Side skirts £40
Sunroof £35
Loom £85
master cylinder and pump £50
ABS bias block £50
Fuel Tank £25
Steering rack £40
Rear Beam £40
Rear drive shafts £85 pair
Hubs front and rear POA
Front and rear disks POA
All others bits available, just ring\text
Simon
07855 433891
Motor £1000
rear diff £140
Prop £75
altenator £45
Starter £40
HT leads £20
Rad and fans £75
2WD intercooler £35
Dump Valve £35
ECU £100
Dash £35
Clocks £35
Side skirts £40
Sunroof £35
Loom £85
ABS bias block £50
Fuel Tank £25
Steering rack £40
Rear Beam £40
Simon
07855 433891
Front disks are £30 or £40 posted
Air filter is 8 inches long
small end diameter is 4 inches
large end diameter is 6 inches
fitted onto ally tube which is 6 and a half inches long going down to 60 mm O\D
I have the ECU, throttle body is with the inlet manifold at the moment, if that doesn't sell complete in the next week I will split it, but no loom at the mo
£100 posted for the ECU
£100 posted for the throttle body with TPS and idle valve
got two front bumpers, £90, and £150 depending on condition
rear beam £40, wishbones are £10 each
hubs are £35 each and yes got two fuel tanks at £25 each
Call me if you require any info
cheers
Simon
07855 433891
cheers
Simon
07855 433891
dojj
28
Sep 11, 2015 10:00 PM
