generators????
Any of you know what size generator would be needed to run a jetwash ie a halfords or karacher type one, and a hoover?
theres loads on ebay but not sure what size i need.
any advice?
cheers
Benn
any advice?
cheers
Benn
Phone Mark One Hire in Rayleigh. They hire the generators out. Tell em you want to hire one to power a car jetwash and ask them what CC/size the generator is! The smallest ones are 2.7kw (you can get smaller elsewhere I think) and im sure that will be fine as i use this size when trading at shows (powering PC/Printer/Cutter/Air Compressor etc..)
HTH
Chris
HTH
Chris
With roughly 2KW needed for a hobby washer and 1200w needed for the vacuum to run them both at the same time your looking at a minimum of a 3.5KW ???
Well remembered Al
I use to run a henry hoover and a karcher pressure washer on a 2.6kva ...shame really as I only sold it last month as I needed the space, but Tonys right in what hes saying. Try Costco as there pretty cheap and do a no quibble excahnge if you fancy a newer model later on
Also if you but the round to square plug adapters beware as they soon melt if used a lot ....
Always go for a little bigger than you actually need ....
No reason, its just they get heavier and bulkier as they get bigger, and its good watching people struggle
(remember to look at the wattage of the kettle too
im watching a couple at the mo, theres a 4kva thats buy now at Ł250 and a few other 3kva at Ł150-Ł200.
Anything else i should look for? These are petrol, thats ok isnt it?
Havent got a clue about these things so any advice would be great
heres some links to ones im watching at the mo
http://cgi.ebay.co.uk/ws/eBayISAPI.d...ADME:B:WN:UK:1
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
DAN@ADRIAN FLUX
37
Sep 20, 2015 10:38 AM
Cowboi
Feb 12, 2006 07:41 PM
foreigneRS
Jun 7, 2005 10:28 AM
cozzie4d
Dec 29, 2004 11:01 AM
