Fuel pipe
Old May 25, 2005 | 09:18 PM
Taz's Avatar
Taz
Visitor from the Darkside
Default Fuel pipe
I have a flat spot on my fuel pipe so I wanted to replace it with stainless braided hose. Technically this is possible but will I need to do anything else. Also what inside diameter would I need?
Graham
Old May 25, 2005 | 11:51 PM
Taz's Avatar
Taz
no answers then??
Old May 26, 2005 | 12:29 AM
NUTS RuS's Avatar
NUTS RuS
What bits are you replacing ?
To do it the proper way with braided it needs connectors and fittings all over the place. -6 (dash 6) will be fine for the hose tho'
Old May 26, 2005 | 11:00 AM
RichardPON's Avatar
RichardPON
Under no circumstances would I ever just use braided pipe on a fuel line and clamp it with a jubilee clip.
That's fine for oil breathers and such things, but never for fuel, as I don't think you'll get a good enough seal.
I would only do it properly from the filer to the fuel rail, but it would incur a lot of expense.
Old May 26, 2005 | 11:06 AM
NUTS RuS's Avatar
NUTS RuS
You would be surprised at how many competition cars are built in that way Rich
Old May 26, 2005 | 11:16 AM
RichardPON's Avatar
RichardPON
I have seen it, and I'm sure someone will say it's fine, but it's just a personal thing of mine that I don't like to see.
Old May 26, 2005 | 11:21 AM
R4N SS's Avatar
R4N SS
i bought a braided hose for this -6 and all the fittings
just gotta fit it now
Old May 26, 2005 | 11:53 AM
NUTS RuS's Avatar
NUTS RuS
Fine for a carb'd vehicle - but I think like you and injection vehicles should be done right.
People also drill holes in a bulk head to pass the pipes through too
Do it once - do it right and use propper bulk head fittings and screw on connectors everywhere. Puts the initial expense up, but should you ever need to replace anything then its only a smaller section that is needed
155lee
Sep 6, 2016 11:10 AM
steve.rst
Mar 15, 2016 08:01 AM
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
