FAO Ryan, re 3 door shell differences
Old May 25, 2005 | 11:19 AM
Default FAO Ryan, re 3 door shell differences
Picture of the rear seat area on my 1.6 GL 3 door A reg shell:
Old May 25, 2005 | 11:52 AM
bttt
Old May 25, 2005 | 11:53 AM
CozzyBrom's Avatar
CozzyBrom
dont forget all the other mods u got to do to it aswell chipper
Old May 25, 2005 | 11:58 AM
Only differences we have spotted are:
tilt and slide roof
towing eye
What else should be different Brom?
The A reg shell even has the same mounting holes for the RS500 cooler (i assume cosworth just reused the normal radiator holes?)
A list of anything else we might have missed would be appreciated mate
Old May 25, 2005 | 12:16 PM
Ryan's Avatar
Ryan
cheers for that chip
Old May 25, 2005 | 07:18 PM
daz1968's Avatar
daz1968
According to manual there is a stengthening plate behind brake master cylinder and the main holes for loom are opened to 65mm, but have never looked at a standard shell to notice if correct
Old May 25, 2005 | 08:17 PM
righthooker's Avatar
righthooker
bracket on the inner O/S wing for the abs cable i think
Old May 25, 2005 | 11:14 PM
pugo's Avatar
pugo
double bracket under front wheel arches for holding brake pipe and abs lead as opposed to single holders on base cars...i think
Old May 25, 2005 | 11:18 PM
Rossco's Avatar
Rossco
Badges????!!!!!
Old May 25, 2005 | 11:56 PM
Yeah there are a few brackets, but they arent the shell just bolted or rivoted on so my mate will just transfer all those over from the 500 shell
Old May 25, 2005 | 11:59 PM
Ryan's Avatar
Ryan
Chip did you get my pictures over PM?
PF crashed just as i sent it
Old May 26, 2005 | 12:04 AM
pugo's Avatar
pugo
the brake line holders are welded in from factory
No mate didnt get them
Old May 26, 2005 | 12:06 AM
Ok, still very easy for my mate to just move them over though, only takes a second to grind it off and weld on.
Will be a doddle compared to welding the roof in for example!
Old May 26, 2005 | 12:11 AM
Ryan's Avatar
Ryan
re-sent
you should have a PM
Old May 26, 2005 | 12:29 AM
Its amazing how many different people want random little bits cut off of the shell.
If anyone wants anything, please dont ask without sending a picture of exactly what you want highlighted clearly.
Old May 26, 2005 | 12:39 AM
CraigN's Avatar
CraigN
chip can i have the fooo fooo valve ?
Old May 26, 2005 | 12:48 AM
CozzyBrom's Avatar
CozzyBrom
chip can i have the rear window surounds
Old May 26, 2005 | 01:33 AM
Phil's Avatar
Phil
Jeebus
Chip can I have the engine?
Old May 26, 2005 | 04:30 AM
Fastmaul's Avatar
Fastmaul
K155MYRS
chip can I have your misses.
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
hopper350
Sep 4, 2015 12:53 AM
