Toad Alarm please help
May 25, 2005 | 10:54 AM
I have a Toad alarm system that was fitted when i bought the vehicle. Dont know which model etc but was working ok.
Since friday it has started makeing a constant noise from the siren.
I unbolted it, unplugged the wire (which obviously stopped the noise), pulgged it back in & all worked fine
for day
Then started again
Anyone had this happen to them? Any ideas
Thx
May 25, 2005 | 10:56 AM
mine used to do that when the cra battery was low!
May 25, 2005 | 11:01 AM
yeah, check the bat chap!
May 25, 2005 | 11:02 AM
It starts the car Ok -everything else workin fine
May 25, 2005 | 11:29 AM
Back up battery for the alarm, not the car battery!!
May 25, 2005 | 11:51 AM
- -where is that then ? its not in the siren
May 25, 2005 | 11:54 AM
Not sure
May 25, 2005 | 11:56 AM
Is it a battery back up siren!? or just a normal 1!?
either way the battery back up is built in2 the siern & just charges off the car battery!
You sure the battery is fine?!
May 25, 2005 | 12:04 PM
There isn`t a key slot in the siren which nomally means its a battery back up i think
Haven`t put a drop tester over the car battery but it always starts fine
May 25, 2005 | 12:08 PM
Correct!
Might b worth puttin in a call to a toad dealer & askin! as there might b different eeps for different things!
May 25, 2005 | 12:14 PM
if its an 'ai606' the one with the black & green siren, the batterys are not avalible seperatly, you buy a new siren, there only about £35.
May 25, 2005 | 09:05 PM
Its got a black siren with a yellow cap on it
Is that the one Guzzler ?
It also continues to make the noise even when the car is running
thought that would have put loads of charge to it and how come if i unplug & then reconnect the siren it stops for a while.
This is driving me crazy
May 26, 2005 | 10:40 AM
Mihgt b best of speakin to a toad expert m8!
as it dont sound like a battery error if its doin it when the car is runnin!
May 26, 2005 | 02:00 PM
hi mate...i know of a guy that knows Toads inside and out...if you want his number PM me and ill send it ya
bassboy
May 26, 2005 | 03:16 PM
Thx Bassboy
You have PM
May 28, 2005 | 09:20 PM
hi danger got a man who is local who fits toad
pm me and ill give you is number
Steve Escos
Alloy wheels and ICE for sale
14
May 8, 2019 02:45 PM
Nov 1, 2015 06:53 PM
Rammer46
Sep 18, 2015 08:31 AM
Iain Mac
Sep 13, 2015 09:16 PM
jdsjojo
Aug 26, 2015 10:09 PM
