wheel spacer when using 4 pots
Old May 24, 2005 | 06:22 PM
JamboRS's Avatar
JamboRS
focus rs 1672
Default wheel spacer when using 4 pots
how wide a wheel spacer will i need to fit rs 7 spokes over 2wd cossie 4 pots?
i have been informed a 3mm will do is this right?
this is on a escort rs turbo
cheers
Old May 24, 2005 | 11:13 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
5mm does the trick but think you mite get away with 3 mm.
Old May 26, 2005 | 01:03 PM
JamboRS's Avatar
JamboRS
focus rs 1672
cheers mate anybody else
Old May 26, 2005 | 01:05 PM
JamesH's Avatar
JamesH
5mm is the norm
Old May 26, 2005 | 01:14 PM
Wazzzer's Avatar
Wazzzer
I had to use 5mm spacer with my League 067s.....
Old May 26, 2005 | 02:57 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Just make sure you use proper Hub-Fitting spacers, that conveniently I can supply!!
I use 5mm on mine.
Old May 26, 2005 | 03:01 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
I used a 5mm spacer on the front, supplied from cossmad on here when using RS 7 spokes on my 2wd saff. HTH
Old May 26, 2005 | 06:25 PM
JamboRS's Avatar
JamboRS
focus rs 1672
cheers peeps
christian pm'd
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
focus2351
Sep 9, 2015 09:33 PM
povey@pembrokeshire
Wheels and Tyres
Sep 9, 2015 06:44 PM
Adam Graham
Sep 6, 2015 06:04 AM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
