co leval
Old May 24, 2005 | 04:12 PM
doggydowg's Avatar
doggydowg
Default co leval
hiya guys is this only adjusted on the electro pressure regulator or are there other ways of doing it?
as a rough guide what co levals do you guys run for 17-18psi i reckon my car is already set up to run hi boost but i have no history on the car and cant afford a rolling road session to find out.
My exhaust is black with soot and im running 14psi and the car was running 18psi when i first got it.
Im hoping i can get a co reading done by a mate so that will give me a rough idea as to what fuel mods have been done, as you can only adjust the fueling for the whole rev range so ive heard?
So if you guys say i need the co leval at 4.00 for 18psi i could get him to do this if mine is under.
Thanks Paul.
Old May 25, 2005 | 10:56 PM
GrimmeRS2K's Avatar
GrimmeRS2K
yep thats the problem with mfi, fuel everywhere, unless a 5th injector is fittted of cause,
the co level i would say 3.5%, give it a rev to 3.5k revs and hold it and see what happens
i had mine lambda checked on the road, at APT, its not that expensive,around Ł80, compared to blowing your engine up, it will cost alot more than Ł80 mate
Old May 27, 2005 | 02:01 PM
doggydowg's Avatar
doggydowg
Where can i get my car sorted prooper or rolling roaded that wont blow my car up baring in min i live in Portsmouth south england?
If i had my car at 3.5% co leval at idle and at 3.5k in neutral would this be on the right track for 18psi then?
Il phone a mate in a bit and see if i can get him to check it over weekend.
Chears in advance Paul.
Old Jun 4, 2005 | 06:21 PM
doggydowg's Avatar
doggydowg
I should be getting the car on the road 2m so im guna get co leval lookd at to see what it reads am i aiming for 3.5%co on idle or at 3.5k in neutral to fuel for 18psi?
Matt Baxter
191
Aug 24, 2013 08:45 PM
skeg
123
Oct 23, 2010 05:57 PM
