New Brakes,Maybe Christian and Beccy???,(Brembo 4pots)
General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
I have a set of 4 Pot Brembo of an alfa, there the same as Focus RS brakes but i want a big brake disc, what is the biggest i can get behind a 16" rim, maybe a Compomotive MO or TH2 alloy, also where can i get brackets made up?
you should get a 330 under a 16 inch mo pnly just thow
the min u can go with tham calipers is 315mm thats it you wont get them on anything smaller due to lug mount
whats the biggest disc you can get behind an rl7 17" brom i need some new discs think the 1,s that came with were shitty 288mm so will this mean new brakets makeing up to go bigger?
rudsta 355s my freind
i know where theres a cheap 355 4pot brembo kit going cheap cheap with alloy brand new bells and braclets
£700 all in calipers are mint aswell
