water contamination in oil after h/gasket failure...
what`s the best way to clean out the engine as the oil has water in!!!
heads sorted.. it`s mainly the block???
cheers paul
cheers paul
do an oil change with some piss oil, run it for a bit, then change it to good oil (well thats what i'd do?)
or else, jus stick fresh oil in? and i'd change the water a couple of times after a few runs. flush out the rad with a hose if it has oil in.
Originally Posted by EssexBoyRacer
Paul, there is something you can buy which flushes it all out.
I'll try and find out what its called for you.
