Reprogrammed fuel ecu: S2 MFI
Old May 19, 2005 | 10:51 PM
GrimmeRS2K's Avatar
GrimmeRS2K
Default Reprogrammed fuel ecu: S2 MFI
Hi, today ive installed a 'Reprogrammed fuel ecu' by superchips, i know they increase the fuel cut in them, but i was wondering if it effects the setup of my engine, the fueling etc, is there other things they could of done to it? does this ecu control the fuel pressure actuator?, i have the fuel pressure mod aswell!.
car still runs spot on as from APT, if anything it seemed it had more pull from 4k revs, but it was a bit colder outside than it has been so proberly that!
Old May 20, 2005 | 09:36 AM
JesseT's Avatar
JesseT
"Reprogrammed fuel ecu"
That black box is from the era when transistor was just discovered. There is nothing in it that can be reprogrammed. Modified, sure.
Yes this box controls the fuel pressure actuator.
Old May 20, 2005 | 11:10 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
your rev limmit may be increased (fuel cut) probably is. .
all that gets changed is a resistor or capacitor here an there afaik.
Old May 20, 2005 | 11:16 AM
KSA-Cossie's Avatar
KSA-Cossie
Yeah it's a resistor that gets changed.
Old May 20, 2005 | 12:28 PM
GrimmeRS2K's Avatar
GrimmeRS2K
so my fueling will be fine then, etc the Co
thanks lads
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
