Trader Parts for Sale. Only Registered PassionFord Traders can sell parts in here. Buy with confidence.
blitz boost controller and spa egt gauge
Old Nov 10, 2003 | 08:13 PM
GaryEvo's Avatar
GaryEvo
Default blitz boost controller and spa egt gauge
am selling my blitz boost controller sbc-id with the power meter
this was over £650 when new
so im after £450 comes with all bits and pieces
also an spa egt and boost gauge with all fittings
was £312 new so £180 THIS IS SOLD...
Old Nov 10, 2003 | 08:57 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
It's like mine, only with a blue display......
(Easily the BEST Boost Controller available.....)
Old Nov 10, 2003 | 10:47 PM
Ginge !'s Avatar
Ginge !
just finding my feet
fook me never new they where that much, fooking nice though, but dont think thell let me pay that much for gauges though , fooking nice though
Old Nov 10, 2003 | 10:59 PM
Norton's Avatar
Norton
thats fookin mint!
wish i had that kinda money to spend
Old Nov 11, 2003 | 08:09 AM
Christian and Beccy
#1 in Spelling Club
The Power Meter will time sprints, and allows you to map the boost on a Speed factor using 4 separate Boost Control channels. Each channel can be get for not only different Boost Levels, but different Gain settings too, which controls how the turbo spools up.
You can also display the boost as a graph allowing you to see how well the boost is held and where it drops. You can also record a certain amount of information.
There are also additional Data channels which can be used to monitor other factors, which can be graphed too.
Old Nov 11, 2003 | 05:28 PM
SOOOO.... IS IT EASY TO WIRE UP TO A S2?
Old Nov 11, 2003 | 05:32 PM
Old Nov 12, 2003 | 06:32 AM
GaryEvo's Avatar
GaryEvo
yes mate very easy
you just need a gearbox speed sensor to use speed part of controller
Old Nov 13, 2003 | 10:19 AM
OK, SO HOW MUCH MONEY, TIME ETC TO FIT A SPEED SENDER UNIT?
Old Nov 13, 2003 | 11:31 AM
Christian and Beccy
#1 in Spelling Club
Virtually none. Go to a scrappy, nick one off a Fiesta or late escort. Take the speedo cable off at the gearbox, screw the speed sensor on where the cable came off. Then screw the cable onto the sensor. It has 3 wires. (Live, Earth and Signal as far as I can remember). It's a piece of proverbial pi55.
Christian and Beccy
#1 in Spelling Club
My Blitz unit is accurate to within about 1-2mph at 160mph.
Old Nov 13, 2003 | 11:37 AM
SO DOES THAT MEAN THAT U CAN BIN THE SPEEDO?
SORRY TO ASK SO MANY QUESTIONS, BUT IT IS ALOT OF MONEY TOO COMMIT!
Old Nov 13, 2003 | 02:27 PM
Christian and Beccy
#1 in Spelling Club
Not sure about the legalities of removing the factory speedo, but the Blitz unit does display accurate speed. If you are after accurate and controllable boost with lots of additional functions you certainly won't be disappointed.
I used the Apexi AVC-R before the Blitz one and the Blitz leaves it for dead. It's dead easy to set up and you can bring the extra functions in as and when you feel comfortable.
It also has an over-boost function, where you set what boost you want to run and where you want the over-boost limit set. If it tries to exceed that limit (which it won't unless its VERY cold etc) then the screen flashes red, the unit beeps and it will immediately back the boost off to a pre-set level to safeguard the engine.
Old Nov 13, 2003 | 05:28 PM
SOUNDS GOOD, IS IT OFF THE CAR ALLREADY?
NORWICH IS ONLY JUST DOWN THE ROAD SO I'LL DRIVE UP AND SEE IT!!
NEXT DAY OFF IS SUNDAY WEEK? IS SCA OPEN THEN?
Old Nov 13, 2003 | 06:35 PM
sjoyce666's Avatar
sjoyce666
do you need a special ECU for one of these to be able to changet the boost stage propery
ive got a S2 ERST and it will be set up to run around 20psi but i dont really want to drive it like this round town, would rather have about 8psi.
Would this help, ive got a superchip at the moment if that helps
Scott
Old Nov 13, 2003 | 07:46 PM
GaryEvo's Avatar
GaryEvo
not open sundays mate
but email me and you can always collect from my house
its off the car and in the box
Old Nov 13, 2003 | 09:26 PM
Christian and Beccy
#1 in Spelling Club
Scott
Would be ideal for what you want. It is totally stand-alone.
Old Nov 17, 2003 | 01:18 PM
CHEERS FOR TODAY GUYS
CANT WAIT TO GET THE BEAST FINISHED
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
