DONT U JUST LOVE THIS LADY..(big pics!!!)
Engine
Carroll Shelby Performance 427 Aluminum FE engine
Shelby Vortech® Supercharger, provides 750 HP
Visteon® F75U high torque starter
8 Quart Canton® oil pan, pick up tube, dip stick
Shelby trim valve covers and air cleaner
850 CFM Holley® Carburetor, Polished single line
Transmission
Upgraded Hi-Torque 5-speed Tremec® TKO transmission
Electronic Speedo®
4130 front & rear u-joints
Balanced aluminum driveshaft sized for transmission
Clutch
12 1/2" Diaphragm clutch
Tilton® hydraulic clutch
Rear End
Currie 31 spline 9" posi-traction trac-locker
3.25 gears
Steering
Power steering Type II
Total Control Products® rack & pinion steering kit
Baer® tracker bump steer adjustable tie rods
Wheels
New 17”X 8” Shelby rims with 245/40ZR17, Z-rated tires
Cooling
Griffin® aluminum cross flow radiator
SPAL® 2 each, 10" electric cooling fan, pull type
SPAL® 1 each, 10" electric cooling fan, push type
Exhaust
JBA® tuned headers with ceramic plating
2 1/2" Spintech® mufflers
2 1/2" aluminum pipe side exhaust system with tips
Dual 2.5" exhaust with “H” pipe
Brakes
Front: Baer® 13 X 1.1 Track System, PBR 2 piston aluminum
Rear: Baer® 12 X .81 Touring System, PBR 1 piston aluminum
Slotted, cross drilled & zinc washed
Adjustable rear bias proportioning valve
Electrical
Trunk mounted battery with heavy-duty cable
MSD® Ignition Control
MSD® Coil
Interior
SCAT Enterprises hi-back wrap around bucket seats
LaCarra® 15” wooden steering wheel for Cobras
JME Enterprises with Auto Meter Shelby Signature Series Gauges
200 MPH speedometer
10,000 RPM tachometer
1/2" roll bar assembly, 4-point
Eclipse® Stereo with CD & amplifier
New technology A/C and heat system
Cascade Audio full sound insulation
Exterior
Shelby emblems
Complete paint & stripes
Special striping for Super Snake(thin-wide-thin)
Functional S/C Cobra style gas lid
Sequential taillights (Shelby style)
Eleanor light package
Suspension
Front: Total Control Products® coil-over kit
Rear: KYB® gas shocks
Shelby style traction bars
Front stock sway bar
Lowering blocks
3.25:1 9" Gears
Fuel
NOS® system – 125 shot
Holley® carburetor
Unleaded gasoline capabilities
1/2 inch stainless braided fuel line
In-line fuel filter
Electric fuel pump and fuel regulation
Transmission
Electronic Speedo®
Clutch
Rear End
3.25 gears
Steering
Wheels
Cooling
Exhaust
Brakes
Electrical
MSD® Coil
Interior
200 MPH speedometer
Exterior
Shelby emblems
Suspension
Lowering blocks
3.25:1 9" Gears
Fuel
Holley® carburetor
In-line fuel filter
If you go through the trouble of building it yourself and have VERY GOOD bodyshop skills it can cost you anywhere between 20-60k dollars, or with bodyshop help about 80k but then I'm sure your going to want a fast engine too huh?
The company that makes those sells them for about 120k dollars.
more like 10p
It wouldn't be so bad if I weren't trying to buy UK-sourced Cossie bits!!
But it did come in handy when we sold one of our UK houses recently and bought a house here in Dallas!! (We still own the London one!)
JK12
33
Apr 26, 2021 12:09 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
slammedorion
15
Nov 1, 2015 07:17 PM
