Losing Coolant
Last wkend i had to top up the coolant as it was on the minimum.
After a week of driving i checked it yesterday and it had gone down to between max and minimum.
Whats most common place for a coolant leak? I've had a look at the rad and theres a kinda wet look to one part of it but when i touched it, the rad was dry
Could be a range of things, rad, split pipe, leaky thermo, heater matrix, or at worst head gasket going. mine likes to loose a bit, but then I know i have a slow heater matrix leak
It will use some water tho you know
Not much else you can do really
Unless the leak is really obvious it's unlikely you will find it without the engine running anyway.
Have you lost performance at all, fan kicking in ok still etc?
The "N" you say? That's a tad high...well depends, are you running a large front mount cooler? Ideally the fan should cut in just after half way up the guage (about in between "O" and "R") and should bring it back down to around the "M" about 1/4 mark... roughly.
If it is getting right up the top that seems exsessive, but again if your running a big cooler then it will get hotter quicker and cool down slower (personal experience)
I'd be checking the thermostat is not sticking myself
I've been quoting my old gauge form my old car
Sorry.
The gauge reads
N
O
R
M
And at the moment it never goes above the M
A lot of the time its under the M
that's the second one 2day
Oh, and now that is cleared up, ignore my post about the thermostat, if its running at normal temps, can't be that....
Keep an eye on it
Look for white salt around all water unions - if you spot any, that is where the leak is. Undo the union, scratch all the salt away, clean up the pipe, and tighten the jubilee clip - problem should then be solved.
mk1focus
Ford Fiesta
Sep 24, 2015 06:19 PM
