heater control - how do you take em out/put em in?
Old May 15, 2005 | 12:53 PM
andre_k's Avatar
andre_k
Default heater control - how do you take em out/put em in?
as above, read haynes but still confused
my twizzly thing that selects the interior air vent positions (windscreen, feet, face etc) on my s2 jammed a while back, out of frustration i turned it as hard as poss, which with a click unjammed it, but there is lil pressure when turning it now, n it dont select the positions
its not the 'groove' in the actual twizzly thing (!?), a fault with the cable maybe? i dunno where to look, ie where the cables go to lol
cheeRS
dre
Old May 15, 2005 | 01:00 PM
pacificzetecturbo's Avatar
pacificzetecturbo
They go yo the matrix behind the centre console mate. put ya head down by the pedels and look left. do the same the other side i cant rember which side they go but thats where the cables end up.
Old May 15, 2005 | 06:24 PM
bzd32's Avatar
bzd32
hi andrek12345
just check the direction nob again now youve freed it off, because that might be broke now.
if not its all in the heater box, at your feet in the middle mate
Old May 15, 2005 | 07:09 PM
TN's Avatar
TN
To take em out simply pull the knobs off one by one
Then behind the controls you will see two screws
Undo them
Then the whole unit should simply pull out
Old May 15, 2005 | 10:29 PM
glenis's Avatar
glenis
Old May 16, 2005 | 12:20 PM
andre_k's Avatar
andre_k
u think ill have to remove center console 1st?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Flatlinedan
Sep 18, 2015 12:41 PM
