Help Help Help
Old May 14, 2005 | 12:58 PM
melzieann's Avatar
melzieann
Default Help Help Help
Can anyone help me, I have a 4x4 cossie and just blown my T3 up can anyone tell me can i put a T34 on with no problems, If so has anyone got one i can purchase this weekend need car on road for monday morning
Thanx
Old May 14, 2005 | 01:01 PM
R4N SS's Avatar
R4N SS
u will need a remap with t34
Old May 14, 2005 | 01:02 PM
Graceland's Avatar
Graceland
Team HOTHOT!
physically it will bolt on, but you will need to get it remapped as Ran says, unless you want it to run dangerouly lean at peak torque
Old May 14, 2005 | 01:08 PM
Ginge !'s Avatar
Ginge !
just finding my feet
yeah ya need a chip to go with it
funny enough i got a stage3 chip for a cossie on T34,,,,,,,,,,, same its form a 2wd cossie
Old May 14, 2005 | 01:09 PM
Ginge !'s Avatar
Ginge !
a chip from MSD is about 200 i belive and its a MOT legal chip and im assuming ya got greens and a 3bar already too
Old May 14, 2005 | 01:24 PM
R4N SS's Avatar
R4N SS
funnily enough i will have a t34 for sale very soon
Old May 14, 2005 | 01:25 PM
Graceland's Avatar
Graceland
Team HOTHOT!
oi Ran you mofo - PM me with some details
Old May 14, 2005 | 01:26 PM
melzieann's Avatar
melzieann
The car is running stage 3 chip, 803 green injectors 3 bar map sensor and i think a 31 actuator, motorsport leads ect.
Old May 14, 2005 | 01:31 PM
Toe Knee's Avatar
Toe Knee
Check with a tuner, but i would have thought if u fitted it and wound the actuator out so its peaking at fuck all boost say 10psi just so u have some it should in theory be ok as it wont be boosting to more than ur T3 was running specially if its stge 3 spec.
But as i say would be best to speak 2 a tuner to be certain its a safe thing 2 do.
Old May 14, 2005 | 01:35 PM
Stu @ M Developments's Avatar
PassionFords Creator
Theres a post all about this here:
https://passionford.com/forum/viewtopic.php?t=73030
It was in technical essays so ive moved it for you to read
Old May 14, 2005 | 01:37 PM
melzieann's Avatar
melzieann
My T3 was boosting 22psi which i know is on its limit, the car was mapped at that but unreliable i thought that if i run a T34 at same boost it would be ok and more reliable
Old May 14, 2005 | 01:55 PM
melzieann's Avatar
melzieann
Thanx for the info looks like sticking with the T3 for a bit till i get it re-mapped, is there anyone with a T3 for sale in good nic
Old May 14, 2005 | 02:27 PM
Ginge !'s Avatar
Ginge !
if ya chip was unreliable then maybe use this as a excuse to upgrade
toe knee, the idea you said wont work as the problem is the fueling under RPM, as in a t3 is on boost ealier and runs out of air earlier so the fueling map would make it rich at lower RPM and lean at high RPM
as for running a chip thats ment for 22psi at 10psi thats also bad too
