dark greens 984's????
m8's just bought some Bosch 0280150984 and HAS been told their the same as usual 803's ie regarding when using in a Cos
n e like to say true or false
PassionFords Creator
Originally Posted by DazC
If they were the same, then they would be 0280 150 803s!
[/quote]
meaning the flow rate of the injector itself
WOULDN'T of thought there would be someone as dim as to think different m8
but from your answer I'm obviously mistaken
but from your answer I'm obviously mistaken Trending Topics
On the note of injectors, wher can i get my 400's flow tested got a feeling i was sold a dodgy set by somebody on here as i know he dont like me and just wana check befrore taking it back to Karl for a re map
Over here some ppl use all kinds of injectors and swear by them even though they are high impedance instead of low.
I guess its hard for someone who never tried the correct setup to tell how it should perform and therefor not noting the lack of smoothness erratic running an ill specced setup would give.
As the saying goes, some ppl cant see the forest because of all the tree's.
I would never risk a YB engine just to save some some pounds by using out of spec injectors.
