Pipes on the amal valve
Old May 13, 2005 | 08:45 AM
davidnormanuk's Avatar
davidnormanuk
Default Pipes on the amal valve
Hi all,
Where do the pipes go on the amal valve for an escort RST?
I know it is on here somewhere but can't see the search tab.
Dave
Old May 13, 2005 | 08:53 AM
db's Avatar
db
I believe this is a link to the topic (hope this works).
See my comments at the bottom of the topic.
https://passionford.com/forum/viewto...asc&highlight=
Old May 13, 2005 | 09:03 AM
davidnormanuk
Thanks for the reply,
I need to know which pipe goes where on the amal valve so I can reconnect it back up.
Dave
Old May 13, 2005 | 01:44 PM
Sketch's Avatar
Sketch
If you look on the AMAL valve i think it has a letter by each of the 3 ports, W, C and R i or similar....
R is the return to the air flow meter
W goes to the actuator
C goes to compressor housing on the turbo
I cant tell you which port is where on the AMAL though, so you'll have to have a good look to see the letters...
HTH
Old May 13, 2005 | 04:47 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
top 1 is too the actuator
middle 1 to compressor housing
bottom 1 to the meter head
thats how it is on mine neways, it was wrong when i 1st got it
i have a question tho, what if you have 2 nipples on the comp housing?? (1 in normal place and another on the 'out' outlet), 1 of my turbo's has that and im unsure so havent fitted it
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
mpilk
Sep 27, 2015 09:21 AM
