What block!!!!
Old May 12, 2005 | 08:35 PM
S2RSsteve's Avatar
S2RSsteve
Default What block!!!!
Can someone settle this argument for me.
What block came as std in the 4x4 saphire cosworth
Old May 12, 2005 | 08:41 PM
Alvyn's Avatar
Alvyn
Old May 12, 2005 | 08:43 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
very very early ones had 205's didnt they?
Old May 13, 2005 | 07:20 AM
S2RSsteve's Avatar
S2RSsteve
Really, Nines a 1993 and it has a 205 block!!
The bottom end had been lightened and balanced and the block i got it off
gave me all the paper work etc.
I was reading PF and noticed the 200 block in the mag was different to mine, So i played detective to find the answer. I had a feeling 4x4's came with a 200 block, I bet he was just a cheap git!!
Old May 13, 2005 | 07:25 AM
Stu @ M Developments's Avatar
PassionFords Creator
ALL 4x4s had a 200 block.
The extra thickness was cast into the crank webs by Cosworth due to having a diff bolted down there on this model.
Old May 13, 2005 | 07:27 AM
S2RSsteve's Avatar
S2RSsteve
I knew it, Mines got a 205 block!!! He had the bottom end lightened and balanced
and various other bits.
What a cheap git!!!
Old May 13, 2005 | 07:38 AM
He probably had a spare engine done to save him being off the road. Doesnt help you though i guess pal
Old May 13, 2005 | 07:52 AM
Alvyn's Avatar
Alvyn
What a cheap git!!!
maybe at the time the bloke COULDN'T get hold of a 200 block so he used the 205 thinking that will do
but as said above ALL 4x4's Sierra/Escos had the 200 block from factory
Old May 13, 2005 | 11:41 AM
S2RSsteve's Avatar
S2RSsteve
Bugger it, Best be on the look out for a 200 block and do a swap around.
Old May 13, 2005 | 01:08 PM
Porkie's Avatar
Porkie
If it aint broke...
Old May 13, 2005 | 01:41 PM
S2RSsteve's Avatar
S2RSsteve
Good point, It's running VERY well to be honest, 350BHP.
As long as i don't go too mental it should be ok for a while.
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
20/20 vision
Sep 28, 2015 03:03 PM
