IDLE is too low
Hi Guys
My car is nearly on the road after lots of work, its now boosting perfect and going well however when it comes to idleing the idle is about 650 for some reason. tried to turn up the idle but its a real pain. any clues guys,
I guess you have two options the first being adjusting the dizzy whilst the cars running, undo both screws but not all the way and advance the timing, the second is to adjust the mixture adjustment screw which is under the cross pipe up to you which you chose but i'd use the first. Hope this helps alittle, Thx Jon
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
