gearbox
Old May 8, 2005 | 10:57 PM
SimoneZ's Avatar
SimoneZ
Default gearbox
hey all, how do u know when a rs gearbox is on its way out? would it make any weird noises ? when changing gears?
and also, hav a problem, when i put my foot down, my car holds back
can any1 help ?
thxs simonez
Old May 8, 2005 | 11:07 PM
GrimmeRS2K's Avatar
GrimmeRS2K
they wine aswell!, if its on gearchange could also be your clutch,pressure plate, when i got mine, thought the gearbox had gone, crunched, and wouldnt go in gear, changed the clutch it was fine
if your car holds back, proberly needs a setup, could be the timing,or fueling, or an air leak somewhere
Old May 9, 2005 | 09:17 AM
AJC's Avatar
AJC
my gearbox rattles like mad and feels loose, just had a Gerarbox built for me using
an IB5 box, uprated pinion shaft and bearings
Old May 10, 2005 | 12:03 AM
HybridBly's Avatar
HybridBly
Hello mate i had a similar problem when i put my foot down, it turned out the top boost hose(the one that the thermostat pipe runs under) had softened due to heat from thermostat pipe and every time it boosted the hose collasped and caused lag, might not be that but worth a look. Hope that helps alittle Thx Jon
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
A.t.p
Sep 29, 2015 05:04 PM
