major oil leak coming form under tray beneath g-box
Old May 7, 2005 | 05:03 PM
Big D's Avatar
Big D
Default major oil leak coming form under tray beneath g-box
Just gone and bought my very first series 2 escort rs turbo
Its been brilliant and been having some great fun. However went out side this morning to find a massive patch of what looks like gearbox oil.
After further inspection it has filled the under tray beneath the gear box with oil and is just dripping out the water holes.
I can not see any leaks from the top of the box and by the looks of things I dont think the drive shaft seals have gone.
Cant seem to get the under tray off eaither as 2 of the studs just turn and cant get another spanner on the other side
Please help
Dave
Old May 7, 2005 | 05:21 PM
Stoo's Avatar
Stoo
Do you mean there is Oil dripping from the cradel for the gearbox?There should be 2 engine mounts attached to this.
If it's the thing im thinking of(which it prob is going by your explanation)i will most probably be gearbox Oil,smell it and see-It should stink of cat piss if it is
It's either(as you say)A seal or the driveshaft has popped out a wee bit
Is it still dripping out?
Old May 7, 2005 | 05:40 PM
bzd32's Avatar
bzd32
it does sound like driveshaft seal, its abit of an ass of a job but cheap to fix
just dont run your gearbox out of oil
Old May 7, 2005 | 05:43 PM
stew205's Avatar
stew205
yes mate its still dripping
What you recon to do then just see if I can go knock it back in
Having said that I went down a big pot hole the other night could this have caused this.
Dave
Old May 7, 2005 | 05:55 PM
bzd32's Avatar
bzd32
its is gear oil that is dipping
Old May 7, 2005 | 06:52 PM
Big D's Avatar
Big D
Just been outside to have another look.
Drive shafts im sure are not leaking as I can see them.
Ive just gone and topped the box up up and yes I have lost alot.
Could the box be to full???? I top it up by taking the black allan key plug out at the front of the box just below the clutch arm and fill it up untill it comes out of the same plug.
I wish I could take that tray off but the 2 studs closer to the rear just will not undoo as all thet happens is the studs go round and round and dont get loose
Im really stuck now
Dave
Old May 7, 2005 | 08:36 PM
Stoo's Avatar
Stoo
Yeah thats how you fill it up,ideally you want the Oil to be about 4mm beneath the hole but dont worry about it,i just fill it up untill it comes back out They take 3.2ltrs by the way
I dont know where else it could be leaking from.Knocking the shafts out by going over a pot hole is unlikley but still a possibility..You can tap these back in but it may be the split pin's at the end are worn and need replaced.They hold the shafts in.Think they cost 18p from Ford as i had to get some the other week because my driveshafts kept popping out
Old May 7, 2005 | 09:29 PM
Stoo's Avatar
Stoo
Oh and if you do manage to take the cradle/tray off be carefull as it's got 2 of 3 engine mounts on it and if the engine isnt supported when you remove it the top mount will get ripped so be carefull mate
Old May 8, 2005 | 07:06 PM
bzd32's Avatar
bzd32
the only other places are the gear selector shaf and input shaft(in the gearbox bellhousing) but unlikely
possible try, pressure washing the gearbox, filling it up and then running it round, then jack the car up and have a good to see where its coming from, because its all guess work at the min
please let us know mate
Old May 8, 2005 | 07:12 PM
RS_JAY's Avatar
RS_JAY
Ive got the same problem. But i know its my shafts. The pins are worn. Not a major leak though. Im saying its your drive shafts. Cant really think what else it would be for the amount of oil to be lost. That cradle is the gearbox/engine mount isnt it??
Old May 8, 2005 | 08:31 PM
Stoo's Avatar
Stoo
Yes mate it is
Old May 8, 2005 | 10:37 PM
GrimmeRS2K's Avatar
GrimmeRS2K
if its not the gearbox, then looks like a crankseal or sumpgasket, my crankseal failed and the oil was pissing out of the drainhole on the tray
Danielbetty
Aug 28, 2015 08:01 PM
st220kyle
16
Aug 14, 2015 06:13 AM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
Dazts1
Was It You?
Aug 2, 2015 06:44 PM
mattman1234
24
Aug 1, 2015 11:46 AM
