s2 cuttin out under boost
Old May 4, 2005 | 09:53 AM
andre_k's Avatar
andre_k
Default s2 cuttin out under boost
may not b in right place, but gets more views here lol
in 3rd, but esp 4th or 5th gear, when on full boost, if you drop the clutch the revs just die and she cuts out...
any ideas? think i read sumwhere awhile ago that it may be crank position sensor...
dre
Old May 4, 2005 | 10:18 AM
Jim Galbally's Avatar
Jim Galbally
do you have a dumpvalve
Old May 4, 2005 | 10:25 AM
andre_k's Avatar
andre_k
yup well lane turbo centres own make, came with car, is silver with 'well lane' machined on it.
goes ptschhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh for about 2 secs, ppl have said it sounds too long lol
could this be it?
Old May 4, 2005 | 10:32 AM
Westy's Avatar
Westy
possibly an air leak.. take the dumper off, and block the hose. See how this goes
Old May 4, 2005 | 10:50 AM
andre_k's Avatar
andre_k
will try, dunno what to use to block it with, and also to block the thin hose on top of it... does the lil 1 need to b plugged?
Old May 4, 2005 | 10:57 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
take the T piece off the lil 'vacum' hose and plug it onto the inlet manifold. . thats that one taken care of.
get a broom handle and cut the end off it, about 2-3" and tighten with a jubilee clip, sorted
Old May 4, 2005 | 11:01 AM
andre_k's Avatar
andre_k
dont get wat u mean bout the lil vacum hose mate... couldnt explain a bit bette could u? a bit slow 2day!
Old May 4, 2005 | 11:16 AM
vroooom ptssssh
It Wasnt Me!
Right soz...
there will be a T-piece where the dump valve vacum hose taps into the original hose, take the T piece Off and connect the original vacum hose from the ECU box - the inlet manifold!
HTH
Old May 4, 2005 | 11:22 AM
andre_k's Avatar
andre_k
will try mate, cheers!
Old May 4, 2005 | 12:02 PM
S2_Steve's Avatar
S2_Steve
hhave you got a crappy cvh oil cap still? had a similiar prob with mine, changed that for a oil cap for one that you lock in using an alan key not had it since and make sure you dip stick isnt loose like the other fella said its an air leak.
be careful of taking the dump valve off when I ask about this a few months ago, few people said they took theyre dump off and they blew the turbo within the week,
Old May 4, 2005 | 12:09 PM
andre_k's Avatar
andre_k
really? am gettin a bailys d.v tomoz so will how that wks...
Old May 4, 2005 | 12:38 PM
vroooom ptssssh
It Wasnt Me!
S2_Steve, nothing to do with the turbo unless its a T4+ running loads of boost i.e. 25psi+
Old May 4, 2005 | 12:48 PM
Wazzzer's Avatar
Wazzzer
you won't have a crank position sensor if its running MFi mate
Old May 4, 2005 | 12:52 PM
Jim Galbally
if it dumps for 2+secs then sounds like the spring is WANKED... lol
leaking dumpvalves (ie 90% of dumpvalves... lol) will cause the car to not idle properly.
it takes seconds to remove the dumpvalve and take it for a spin round the block to test it... go n do it now mate
Old May 4, 2005 | 01:08 PM
andre_k's Avatar
andre_k
im on my moms pc, dunno how id block the dv take off pipe here! i ant gonna cut up 1 of her brooms! ill have a look around 4 summink...
Old May 4, 2005 | 02:09 PM
CabrioTurbo's Avatar
CabrioTurbo
just cut her broom up!
otherwise i find a tip-ex bottle fits nicely also
Old May 4, 2005 | 02:12 PM
Jim Galbally
the little one from the top, if you cant just take it off completely, get a self tapper screw, these fit in there nicely if you get one the right size
as for the big hole... there are loads of household items that'll fit in the hole nicely
Old May 4, 2005 | 02:20 PM
K3V HA's Avatar
K3V HA
Andre, take the dump valve off, it drove better without one anyway!!
Old May 4, 2005 | 02:25 PM
andre_k's Avatar
andre_k
cheers mate, will do! so i presume webbhoy bought it off u?!? u have pm
Old May 4, 2005 | 02:28 PM
The Gravedigger's Avatar
The Gravedigger
No way man! A DV saves the life of many turbos, big and small!
Old May 4, 2005 | 02:30 PM
Jim Galbally
GD, prove it
Old May 4, 2005 | 06:49 PM
vroooom ptssssh
It Wasnt Me!
Bollarx, damn wish the search function was bk for that multiple thread on it
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
