cuts out under full boost
hi there,
Its not blowing off your oil filler cap or dip stick, when boosting is it.
because it the crank pressure is to high it will lift them up on boost and because of the way the breathing system works it will not idle or the seals could just be worn and need replacing.
hope this helps
hope this helps
Originally Posted by andrek12345
no trouble with blowin off cap or dipstick, i have heard summink about a gunged up crank pos sensor causin it to cut out... dunno where exactly on g/box it is
mine does the same thing after booting it and let off, it will cut out, its because of the dumpvalve not closing quicker enough, take it off and u will see, or buy a new dumpvalve, spring could soggy
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
