Can peeps with XP do me a quick favour please
Old May 3, 2005 | 06:49 PM
Gra's Avatar
Gra
Default Can peeps with XP do me a quick favour please
Can you go to C:Windows and see if you can see your System32 folder please
Old May 3, 2005 | 06:50 PM
Matt's Avatar
Matt
its hidden by default gra
Billabong's Avatar
Billabong
Nope, but I can see it in my WINNT folder (XP Pro....)
Old May 3, 2005 | 06:53 PM
Billabong's Avatar
Billabong
Old May 3, 2005 | 07:01 PM
Gra's Avatar
Gra
but showing all folders etc should allow you to see it should it not?
Old May 3, 2005 | 07:05 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
If it really wasn't there, XP wouldn't work at all.
Old May 3, 2005 | 07:09 PM
Petrucci's Avatar
Petrucci
system32 directory is not hidden by default mate, so you should see it when entering your windows directory, yes. HTH.
Old May 3, 2005 | 07:12 PM
Matt's Avatar
Matt
the whole contents of c:\windows is hidden by default using explorer (same as c:\program files). theres a button to click in the right hand pane to enable viewing
Old May 3, 2005 | 07:22 PM
Petrucci's Avatar
Petrucci
don't confuse things Gra : the content does not show until you click on the button stated above, but the directory attribute is not hidden. so basically if you can see the rest of your windows directory (ie cursors, fonts etc) you should also see the directory system32
Old May 3, 2005 | 07:29 PM
Matt's Avatar
Matt
agreed this time round
Old May 3, 2005 | 08:23 PM
Gra's Avatar
Gra
cheers, the folder is ther as i can get to it via the run menu, but i cannot see this one folder, plus my regedit is up the spout, i can only access this going to the windows folder etc etc, and not using the run command if that makes sense, lots of strange things going wrong, plus cannot system resotr either, so a format is needed me thinks
Old May 3, 2005 | 09:10 PM
Jim Galbally's Avatar
Jim Galbally
gra, try runnin the recovery thingie on the windows CD (as if youre re-installing) i did it on a PC the other week and it fixed it 1st time
worth a try if you cant be arsed to re-install
Jim Galbally
oh and bill, the Xp pro default install dir is also c:\windows
Old May 3, 2005 | 09:36 PM
Redkop's Avatar
Redkop
Go here It's the most helpful forum on the net for PC problems
Old May 3, 2005 | 10:06 PM
markk's Avatar
markk
i can see it and it is in c:\windows
so bil - looks like its for you all courtesy of mr G .
Old May 4, 2005 | 07:16 AM
Markb_s1's Avatar
Markb_s1
bill's is an upgrade
Old May 4, 2005 | 08:09 AM
Gra's Avatar
Gra
cheers peeps, formatted the mofo last night, and everythings now sorted.
I dunno what i had infecting the pc, but regedit would start a CMD prompt etc, i was using Adaware pro, and spysweeper plus norton etc and regardless of what it found on reboot i would be infected again and again, spysweeper was finding 50+ after every reboot
Gra's Avatar
Gra
cheers for the link red
Old May 4, 2005 | 08:20 AM
Petrucci's Avatar
Petrucci
Bill has got his winxp installed in WINNT directory because he upgraded from Windows 2000
When installing Windows XP from scratch, whether it's home or pro, it's always in WINDOWS directory.
tankybaby66
Feb 6, 2016 02:24 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
DixieTheKid
Sep 14, 2015 09:04 PM
