fueling prob ....................
Right car is all back together but wont start its got a spark just no fuel getting thew.the pump buzzes when turn ignition on so sound like that is working ive cracked off one off the nuts on top of metering unit and cranked over an not a drop came out
ive changed loom in car so dont no if might be a plug on wrong?????or metering unit fcuked but it worked fine before but car has been off road a year now.......
any ideas????
cheers
jon
ive changed loom in car so dont no if might be a plug on wrong?????or metering unit fcuked but it worked fine before but car has been off road a year now.......any ideas????
cheers
jon
right got told today to push flap down on metering unit when starting it. it didnt start but i now have fuel coming out if crack off bolt but none comes out of injectors still
so it sounds like fuel pump not got enough pressure or metering head fcuked what do u rekon as done want to buy stuff i dont need
jon
jon
HI,
Try the fuel pressure regulator as this is for as it says system pressure and differential pressure with the metering unit,
try and make sure you have no airlocks in the system, take the return pipe off the
regulator leading back to the tank, and bypass the fuel injection relay by removing
the relay and by bridging pins 30 and 87 at the relay the fuel pump will run continuously may need ignition on, and run the system for about a minute
if you can fit a pipe into the return port of the regulator put it into a bottle or
what ever and do a delivery check, and with a stop watch get someone to start the
fuel pump and get them to stop it at 1min, you should have minimun delivery of
fuel of 1100cc, or 1/2 of that at 30sec's on stop watch, if not fault could be volts
to pump should be 11.5v minimun with pump running,fuel filter dirty,or filter in metering unit blocked,
any other checks need fuel pressure kit to check out system properly.
also make sure the return to the tank is not blocked or the pipe kinked
DAVE R
DAVE R
cheers mate tried it seems like was air lock as got loads fuel coming thew now that much its compleatly flooded engine
oil change and should fingers crossed start this time
jon
jon
