SPARK PLUG GAP - help!
Old May 2, 2005 | 09:41 PM
glenis's Avatar
glenis
Default SPARK PLUG GAP - help!
What is the correct gap for plugs in an ERST S2 ?
I assume when buying some and fitting them straight away is not clever...
What should they be set at please ?
Old May 2, 2005 | 09:51 PM
Nice_aRSe's Avatar
Nice_aRSe
Depends on your boost, if its uprated i'd set em to about 0.6mm
Old May 2, 2005 | 09:54 PM
glenis's Avatar
glenis
how do you re-gap them if say, they come out of the box at 1mm ?
you close the gap down using what ?
Old May 2, 2005 | 10:03 PM
DazC's Avatar
DazC
Tap them gently with a toffee hammer or against a flat surface.
Old May 3, 2005 | 09:05 AM
GrimmeRS2K's Avatar
GrimmeRS2K
if ur running high boost, u need to close the gap a bit, as mine blew the spark out when running high boost
Old May 3, 2005 | 11:46 AM
220TC's Avatar
220TC
I believe the standard gap is 0.8mm, I was running a stage 3 head & turbo at 22psi and stu advised me to gap them to 0.7mm. Hope this helps.
Duncan
Old May 3, 2005 | 12:05 PM
glenis's Avatar
glenis
0.6mm wont make much difference from 0.7mm will it ?
Old May 3, 2005 | 01:48 PM
Nice_aRSe's Avatar
Nice_aRSe
It does make a difference mate.
Set em to 0.6mm you need to get a fieler gauge on them to check the gap and as someone said tap them against sumthign ever so gently.
Old May 3, 2005 | 02:32 PM
glenis's Avatar
glenis
are the tips quite durable ?
I mean if they are gently hammered against a flat wall, it wont make them weaker or shit will it ?
A scratch or two will be ok ?
Old May 3, 2005 | 02:52 PM
Nice_aRSe's Avatar
Nice_aRSe
Bang them gently on a wooden surface, wont scratch em then
It really is only lightly you have to tap them mate
Old May 3, 2005 | 02:55 PM
glenis's Avatar
glenis
yeah i done one set already
against a wall though...
will they still be ok ? if slighty scratched
Old May 3, 2005 | 02:57 PM
Nice_aRSe's Avatar
Nice_aRSe
Yeah should be ok mate, use wood next tiem tho
Old May 3, 2005 | 03:05 PM
glenis's Avatar
glenis
i find it difficult though, as one hand had to hold the plug, and one hand holding the rubber mallet
and the third hand was tying to hold the feel gauge at the same time...
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
