how to remove fusebox???
Old May 1, 2005 | 06:38 PM
Daz-rst's Avatar
Daz-rst
Default how to remove fusebox???
how do i remove the fusebox from me S2 as its got water under it!!!!!!!!!!!! also is there anyway of preventing water from getting there????
cheers
daz
Old May 1, 2005 | 06:45 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Ok...
The top part where all the fuses are lifts up at the front. It is clipped in and comes away from the base which is screwwed down to the body with 2 screws. Unclipping the top gives you enough room to get a screwdriver in there to undo the screws then it just lifts out.
HTH
Old May 2, 2005 | 12:19 AM
adamS2RST's Avatar
adamS2RST
Always wondered how they came out Cheers Tone
Old May 2, 2005 | 10:53 AM
Daz-rst's Avatar
Daz-rst
Default cheers fella
cheers fella. any way of preventing water from getting in there as i dont wanna keep having to remove and replace it cause soon it`ll turn into something serious!!!!
Old May 2, 2005 | 11:26 AM
glenis's Avatar
glenis
sealant of some sort ?
Old May 2, 2005 | 05:29 PM
Tony Turbo's Avatar
Tony Turbo
There is meant to be a rubber ring/ boot around the hole.
If water is getting in, chances are you have a little rust hole
Old May 2, 2005 | 06:34 PM
DazC's Avatar
DazC
They usually rust at the front of the hol;e where the bulkhead is and also the scuttle panel rots behind the windcreen rubber on the seam. Both areas will let water into the cabin.
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
