Oil return pipe split s2!!!
Old May 1, 2005 | 06:24 PM
Mr.h.'s Avatar
Mr.h.
Default Oil return pipe split s2!!!
The rubber pipe that goes from the bottom of the turbo and into the bottom of the block has split wide open! Can i get a new one from ford or should i get a silicone replacement from another company such as samco or sfs or roose??
Also would this leak affect performance ie, pressure loses ect???
Any feed bk welcome
Nick
Old May 1, 2005 | 06:27 PM
cooler king's Avatar
cooler king
think if its the one im thinking of, its a ford only part and its £38!!!!! mine went and i couldnt find a replacement, ended up gettin a ford one???? is it the one thats got a bend in it?
Old May 1, 2005 | 06:35 PM
Mr.h.'s Avatar
Mr.h.
thats the one mate!!!
I had the same prob with my old s2 the red one in my sig, i just used a hose that i had lying around
There must b a cheaper option than what ford want???
Old May 1, 2005 | 06:47 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
It's true, Ford ones are a fortune. If it's split you will loose oil, which will eventually lead to severe performance loss lol.
There must be a way of using aeroquip to do this. It will cost more but will never split.
Old May 1, 2005 | 08:40 PM
Mr.h.'s Avatar
Mr.h.
I realize that it will lead to a severely fooked engine eventualy but does the whole turbo system need to presurized?
What im trying to say is does any kind of leek of presure lead to lack of performance as mine is slow as shite at the mo
Nick
Old May 1, 2005 | 10:35 PM
AKRS1's Avatar
AKRS1
bought one for £35 plus vat from ford a couple of months back cant believe how expensive it was for a small piece of rubber pipe
Old May 1, 2005 | 10:40 PM
turbo.jon's Avatar
turbo.jon
Ive used a piece of straight pipe which i had spare from my breather system pipe i got it all from local hydrulics company got few bits spare if u need any????works fine no kinks in it fitted on fine
Old May 1, 2005 | 11:01 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
i just done mine with a piece of oil hose suitable i had lying around. makesure it IS oil hose tho as it will just perish rapidly. you can fit it and off you go, no need to represhurise the turbo oil system. but DONT use the car if it is leaking. and alsho check oil when you've fixed it!!!!
Old May 2, 2005 | 09:49 AM
Mr.h.'s Avatar
Mr.h.
Thanks for the offer mate but i think ill gop and get a hose made up as i need a couple others made aswell!
Thanks for everyones help
Nick
155lee
Oct 27, 2015 04:55 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
krypton
Sep 23, 2015 07:29 PM
Chopshop85
Sep 18, 2015 06:13 AM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
