Fiesta turbo Missfire
Old May 1, 2005 | 04:56 PM
bud-weis's Avatar
bud-weis
Football Cwazy
Default Fiesta turbo Missfire
the car has developed a bit of a miss. basically on light throttle and just at the moment you depress the accelerator the car misses.but if you continue to accelerate the car will pull through it.changed the leads today and still not cured it, plugs are fine. my thinking is that it's the coil pack playing up? anybody know if these are problematic. my other thought is the TPS although the one on the car is fairly new. would appreciate any tests, checks etc i could try. also are coil packs model specific or would any efi equipped car use the same one?
thanks guys and girls
Old May 4, 2005 | 08:52 PM
fizzyturbo's Avatar
fizzyturbo
is there a knock when you back off, because thats what happened and i had a big end bearing gone.
Old May 4, 2005 | 10:58 PM
bud-weis's Avatar
bud-weis
Football Cwazy
no no no no !!! better not be cos it's a damn expensive engine!!! no it definitely isn't that. i have actually made it a lot better simply by using my diagnostics tester on it. bought up some completely random bullshit fault codes but the car ran better afterwards. thanks for the input though
Matt Baxter
Sep 16, 2015 08:30 PM
paceo
Aug 27, 2015 12:45 PM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
ginger1979
Jul 31, 2015 09:56 PM
