Oil Filler cap trying to get off!
Old Apr 30, 2005 | 10:51 PM
Poom's Avatar
Poom
Default Oil Filler cap trying to get off!
Everytime I give the car a bit of a thrash the oil cap tries to jump off which eventually causes my car to cut out on idle if I dont push it back down!
I have been told I need a breather system...is there anything else I can do in the meantime to try and prevent this?
Old Apr 30, 2005 | 10:53 PM
Lee Reynolds's Avatar
Lee Reynolds
yes tape it on
Old Apr 30, 2005 | 11:00 PM
Alan s1's Avatar
Alan s1
I take it its a cvh
Try a new cap as the rubber gets melts some times
That or a breater sytem as it probley breathing aa bit heavy
Or as LEE said tape it on
Old Apr 30, 2005 | 11:02 PM
RSeb's Avatar
RSeb
hope its nothing more serious crankcase compression could be worn rings nasty business
Old Apr 30, 2005 | 11:34 PM
xr4x4rs's Avatar
xr4x4rs
its not rings the car runs perfect and doesnt smoke
told u to get a breather on it
Old Apr 30, 2005 | 11:53 PM
Shings's Avatar
Shings
Easiest thing to do is clean it all up inside and clean where it sits on the rocker cover.
A few times round with some black insulation tape and jobs a good one it will stay on.
Get a breather kit from one of the traders.
70-80 quid will see you with a nice 2nd hand bailey breather and prob the pipes to go with it.
J
Old May 1, 2005 | 12:06 AM
mattbibs's Avatar
mattbibs
breather system is normally a cover up for ring damage.
hope its not the rings - try the breather - definitely the cheaper option!
Old May 1, 2005 | 02:35 AM
digita1dragon's Avatar
digita1dragon
I got a nice fusion breather pot thing second hand, mines not popped off since!
Old May 1, 2005 | 07:25 AM
edd's Avatar
edd
if the breathers are not blocked/cant cope your rings are most deffo fucked mate.
Old May 1, 2005 | 08:16 AM
GUZZLER's Avatar
GUZZLER
well worth fitting a breather imo. but first get a new genuine ford cap,
most 'pattern' ones don't seal aswell, an if your cap is a bit old, as said above, the seal gets poor.
Old May 1, 2005 | 09:58 AM
Little Joe's Avatar
Little Joe
Yeah Tape it.
Old May 1, 2005 | 11:27 AM
Porkie's Avatar
Porkie
Stu told me the best thing to do is get one of those special bufty shiny caps that have the screws in them to fix them on real tight. He just loves these and wishes that Motorsport developments had thought of these first.
JOKE!!!!!!! before Stu sends someone round to kill me! If the cap is in good condition, then as other people have already said there is a good reason the cap is coming off.
Old May 1, 2005 | 11:58 AM
Paddy's Avatar
Paddy
Legend
I tried to kid myself that a breather system was all I needed to stop the cap popping off [even the dipstick shot out when it was having a power run at Engine Advantages ]
I put a bailey system on tho and it was ok for a bit, but just hiding an underlying problem.
Which is why my bottom end is now in bits
Get it looked at properly, get a compression test done [just for peace of mind if anything] befoe you wind up doing more damage than just a set of rings [Like me ]
Old May 1, 2005 | 12:10 PM
Ginge !'s Avatar
Ginge !
just finding my feet
cable tie the cap the cable tie to wear the car wire thing holds it on and pull tight, job done u till meltdown
Old May 1, 2005 | 12:11 PM
Paddy's Avatar
Paddy
Legend
My kinda man
Old May 1, 2005 | 12:15 PM
DAN P's Avatar
DAN P
my xr2 was doing this so went to ford got a new cap did not blow of after that o and if your running more than 10 psi get a breather
Old May 1, 2005 | 12:18 PM
Ginge !'s Avatar
Ginge !
well thats what we done on the way to central day, was having a laugh and the filler cap fell off, as we had a spare we came up with the fix it solution, rebuild time, fook no, grab the cable ties and we will fix it perminantly !!!!!
melted 2 pistons and a plug tip looked not too good on number 3 on the high speed fun on the way back
only minor meltdown though
Old May 1, 2005 | 12:40 PM
Oranoco's Avatar
Oranoco
Not on the Cossie Ginge?
Old May 1, 2005 | 12:48 PM
Tim's Avatar
Tim
Most breather systems dont use a large enough exit pipe blow by will always happen with 25 psi plus,always use a large exit breather.
Tim
Old May 1, 2005 | 12:58 PM
DazC's Avatar
DazC
Use a bit of Jim Galbally patented gaffa tape...
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
Brickhouse
Sep 21, 2015 11:00 AM
