Need advise on the cossie ..................................
Ok just yesterday and today the cossie has be playing up
Not surprised its nice warm weather and its goes tits up
All the crap weather she was going well
Right then ;
When i have been driven it OFF boost for say about 20/30 mins or so its starts playing up,
I go to put my foot down and it splutters and pops and Banges ALOT also the Rev gauge jumps all over the place It was getting worse ans worse so i go it home and have left it
When ever i have been driven it hard it seems to have been FINE
Could this be a sencer breaking down like the one in the dizzy As this one has been replaced once as it would'nt start ect due to it
Ps its been over fueling for a bit
And also has a missfire which has been p!!sing me off a bit
as i have tried every thing i can think of
When i got the car is was running very poor and turns out the CAM BELT was 1 tooth out on one of the vernor pully so it may have damaged a value or some thing (have'nt removed the head yet) could this bee the missfire ???
Any help ??? thing to look for ???
Right then ;
JimRS, Well i have'nt but i will
Also the compession is down to ; 90/80/80/90 So its Low but with in 10% ??? so i have been told
It seems when its hot or hot weather
sounds like crank position sensor is failing - this is on the front of the timing case cover under the crank pully - check that it isnt caked in much and that the wiring isn't broken as it gets very brittle with age, clean the sensor head up as if there are any metallic bits on this, then it will sence them as its just a proximity sensor at the end of the day
Would the Yb be the as the Twin Can engine then
Nigel give me abell im off untill tuesday so when ever you want to pop over m8
If you want to have a look at the cossie for me i'll get the beers in ready
On monday im help the mother and father in-law move
In the morning but i can sort some thing out
cheack the alternator !!!!!
if its cutting the rev counter and then comes back on and when ya floor it on idle it splitters but if gentle its fine then check that as thats what mine was
Ginge It drives ok untill yo put your foot down
When sat on idle its fine rev it its Poping and Banging
So tested it to see whot voltage its putting out yer
I must admit it was'nt pulling over 60 ish coming back due to it cutting the revs
check your coil mate
could be playing up and dont the rev countre run off this aswell
just change it for a new one if you havent already
my mate had similar problem and thats what it turned out to be
hope that helps
hope that helps
hope that helps
hope that helps
Mines doing exactly the same
fine at low revs but accelerate to say between 3 and 4 thou the rev counter shoots up to 7. Gives the odd splutter aswell. I thought my plugs were on the way out again but that didnt explain the rev counter thing
herb, Thats about right m8 3 and 4k the rev counters all over the palace
Well i put a new set of plugs in it 2wks ago so far it had new ever thing ??
Unless its a power draain like Ginge said try or the carank sensor playing up
ok is it cutting the power liek a boost limit cut, if so test the altanator with the lights on at 3k rpm, the power should be over 12v, if its lower like mine was the alts not giving the bat the charge and so the ecu is cutting it till it recives it
trust me as i keft mine cause when i drive gentle its fine, but on the way back fro central day the batt was totally dead ( mind was racing on te A407 for a few miles ay a steady pace, me pother mate melted his piston and done his headgasket there too
Yes Ginge that makes sence
Ps on the way to central day i got 150mph (clock reading and i was well happy with that ) out my cossie when passed the old bill @ 140 tho
And me going S!!T whot they doing out this time of the morning
Mind you i was doing 90mph above the limit The resst of the way was with my m8 in his escos doing the speed limits like good boys
dont know anyonewho had problems with the grp a mate so that should eliminate my theory
id with the alternator idea first as mentioned
also check your connectors behind the battery where the engine loom plugs in
a long shot like but on my cossie the connectors kept coming apart due to being broken clips and that gave me the same signs
crank sensor if playing up would i think play up while driving slow aswell as fast but worth a shot
oh god how i miss cossie owner ship got all this to come again soon
hope you find it mate good luck
Check the wiring from the negative terminal of the coil (i.e. green wiring).
It splits into 2, one wire goes off to the revcounter (through a filter if it's like my Cossie loom) and the other one goes to the ECU. I have exactly the same symptoms as you guys and I have replaced CPS and checked that side of things out with a multimeter.
I replaced ignition amplifier module, ECU itself, checked Pectel board, replaced the coil with another one to see if that was the cause (it wasn't and coil is working properly on another Cossie) and I've now resorted to removing the engine loom completely to see if I can locate where the fault is.
The trouble is my car started off with the misfiring, then it misfired and cut out and now it won't spark when turning over, even though the injectors etc. are firing (meaning the new CPS is working - confirmed as we tested it when turning over). It intermittently fires up as well when fiddling with the wiring meaning that I've got a break in the loom somewhere!
Hopefully you'll find your problem easier than I'm finding mine though!
Cheers,
Andy
Cheers,
Andy
Cheers,
Andy
Cheers,
Andy
Im thinking mine maybe braking down again As aparntly thats wont it does it slowly brakes down then goes all toghter
Now i have problems again
Hope you sort it
Ginge i did the same thing with my s1 then 1 1/2 months later i toke it down essex to my mum and dads to work on it ect and turn out to be a simple thing like the metering unit
All the time not doing any thing to it it turns out to be as simple as that
So im going to try and sort the cossie as soon asap as its up for mot now anyway
[quote="Alan s1"]
quote]
driving it hard why it's running like that.................................
tut, tut, your lucky you only have a missfire
get it sorted ASAP.
(remember it Middx RSOC tomorrow)
quote]
get it sorted ASAP.
Cheers,
Andy
Cheers,
Andy
Hope you sort it
I've got a strong suspicion it's an earth problem but could also possibly be the rpm signal to the ECU.
Cheers,
Andy
The PHASE SENCOR in the dizzy I beleave thats whot its called as mine had a chip out the plug that clip on it so the garage replaced it and it was running fine
I was told there not cheap as he manged to get a second hnd one of a m8
Worth looking @ as the controls the spark ect
Cheers,
Andy
Russ Payne
Sep 25, 2015 08:29 PM
