If a car has these problems ...
Old Apr 30, 2005 | 06:50 PM
RA052824's Avatar
RA052824
Default If a car has these problems ...
... how easy would it be to sort them out so everything is running smoothly!
The starter motor clicks repeatedly before it will catch and turn over (once turning it starts almost instantly).
There is a noise from what i suspect is the top end, sounds very much like the tappets or noisy injectors but cant be 100%
Wiring loom requires tidying really, Rev counter doesnt work, due to this, and fuel pump is seperatly switched on and off.
Old Apr 30, 2005 | 06:54 PM
Phil's Avatar
Phil
Jeebus
Nothing too bad there really, just depends on whatthe problems really are!
Starter motor could be half dead (usually easy to change depending on what car it is) or the wiring could be knackered (poor feed or earth)
Engine noise could be tappets or oculd be piston slap etc, usually hard to tell unles you know what you are doing.
Wiring loom replacement isn't too bad a job but quite labour intensive unless you do it yourself. (Assuming a 2wd saph on that one!)
Old Apr 30, 2005 | 06:58 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
a hammer will sort all that out
Old Apr 30, 2005 | 07:10 PM
RA052824's Avatar
RA052824
Have a look at THIS!
mk22door
49
Mar 26, 2022 07:15 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ginger1979
Jul 31, 2015 09:56 PM
