speakers
Old Apr 29, 2005 | 08:41 PM
steviep's Avatar
steviep
Default speakers
anyone know what size speakers can be fitted into the front and back of a sapphire withot hacking the doors/shelf about?
Old Apr 30, 2005 | 08:03 AM
john_p_b's Avatar
john_p_b
13cm fit straight in the front doors although be a bit carefull on the mag depth as the window drops very close to the back of it!
think the rears are the same if you want to make them fit in the original mounts although i've not yet got around to mine yet so don't quote me on the rears!
Old Apr 30, 2005 | 09:44 PM
snow*'s Avatar
snow*
Hey steviep
As john has just said 5.25" or 13cm speakers will fit straight into both the front door cards and also the rear plastic boxes that sit on the parel tray.
I've just recently installed a new Headunit and also 4 speakers and a pair of tweeters and was in the same boat as you. "I didnt want to chop or alter anything"
The rear speakers sit ontop of these funny plastic surrounds there is only 1 bolt that holds them inplace so getting them out is easy, but separating the old speakers from the plastic boxes and mesh grille is rather tricky
I'll post some pics here soon
Old May 1, 2005 | 05:25 PM
steviep's Avatar
steviep
cheers guys, any idea on the depth of the fronts cos my missus wants to get me some better speakers for my birthday next week but I won't have time to take the originals out to measure them before then
Old May 1, 2005 | 07:54 PM
snow*'s Avatar
snow*
Hey steviep, its literally a 2 minute job to unscrew the door skin and whip out the old speaker.
Having just installed my new speakers Im not that keen on taking them out.
I'll measure the origianl ford ones that I took out for you
I do remember measuring the distance before I would have trouble with the windows and from memory it was no deeper that 75mm, ie a speaker no deeper than 75mm.
Hope this is of some help
Old May 1, 2005 | 09:29 PM
john_p_b's Avatar
john_p_b
i've just put some of there http://www.cdtaudio.com/Classic_Braxial.htm in the front of mine, not cheap but worth every penny if you value your sounds! mount depth is listed as 2 3/8" so i guess that works out to 70mm ish and they are a tight enough fit!
Old May 3, 2005 | 04:17 PM
steviep's Avatar
steviep
cheers lads
TrevCos
Alloy wheels and ICE for sale
Sep 13, 2015 02:12 PM
mayo rs
Ford Escort RS Cosworth
Sep 1, 2015 10:18 PM
cameron2
Aug 30, 2015 08:15 PM
borboyous
Aug 22, 2015 11:17 AM
