PIC OF BAILEY TURBO DAMPER NEEDED PLEASE
thanks mike but I need to see how the bolts & washers are arranged onto the turbo
Lewisyes they're there, picked it up at 11 last night from the depot
cheers Jon, see you later. deffo need those brakes now, running sweet & on 26psi.
standards aren't much good when a transit pulls out in front when I'm doing 130+
If you do fit it Ian, make sure you "hammer" the 3 legs into position on the rocker cover - don't rely on the M6 rocker cover bolts to pull it into position or you could strip a thread in the head.
JoeyBoyden
Jan 4, 2024 02:36 PM
big_Rad
Sep 15, 2017 09:36 AM
