Cosworth brakes
Old Apr 29, 2005 | 09:00 AM
DanS2i's Avatar
DanS2i
Default Cosworth brakes
Can you fit cosworth brakes behind a standard S2 alloy wheel?
Thanks
Dan
Old Apr 29, 2005 | 09:46 AM
glenis's Avatar
glenis
yes you can
285mm, as opposed to 260mm standard RST brakes
Old Apr 29, 2005 | 01:35 PM
DanS2i's Avatar
DanS2i
Cheers!
Would I need to use 4x4 Cosworth calipers and discs?
Thanks
Dan
Old Apr 29, 2005 | 01:37 PM
glenis's Avatar
glenis
i dont think so...
i think 2wd discs and calipers fit as well, providing you have the special mounting brackets...
4 pot calipers, from a cossie... get them
Old Apr 29, 2005 | 08:05 PM
ON-UJAH's Avatar
ON-UJAH
You can get brackets for S2 calipers with 283mm Cossie 2WD discs - try Clint at Turbosport.
Old Apr 30, 2005 | 09:26 PM
gavintwopies's Avatar
gavintwopies
i dont think so...
we have had a right headache with this this week yes you can get them to fit however you will need nearly 15mm wheel spacers to get them to fit behind the std s2 alloys, which is a bit much really looked like an offroader and caught the arch on full lock...............................not good, need after market alloys with enough clearance as std or some 2wd alloys
Old Apr 30, 2005 | 09:39 PM
glenis's Avatar
glenis
i had 15mm spacers on my old 300mm ST170 conversion
with 17's though
original
Apr 28, 2026 05:20 PM
cossie4x4
Aug 14, 2015 06:29 PM
Aug 14, 2015 07:29 AM
Red_bull
Aug 9, 2015 08:34 AM
Old ford
Jul 31, 2015 06:50 AM
