Mondeo auto gearbox problem -definetly low oil - Question?
Old Apr 28, 2005 | 05:31 PM
Jon ERST S2's Avatar
Jon ERST S2
Default Mondeo auto gearbox problem -definetly low oil - Question?
Sometimes doesn't go into gear straight away. Like your in Drive and you pull up to roundabout and just revs a little bit i.e as if your in neutral then goes. Only does it now and again at the moment. Is there anything simple I can check?
BTW It's a 1.8GLX Mondeo.
Old Apr 28, 2005 | 05:35 PM
SPADGE's Avatar
SPADGE
Check the oil level
If that is ok then you could try dropping the sump off the box and cleaning out the filter.
Most likely to be the clutch's in the box are worn though!
Old Apr 28, 2005 | 05:42 PM
Jon ERST S2
cheers. I'll have a look.
Whats the damage for a clutch on an auto box? Is it a lot more than on a manual?
Old Apr 28, 2005 | 05:44 PM
SPADGE's Avatar
SPADGE
Different thing altogether mate
If the clutch's inside an auto box are fooked then the box is scrap!
Old Apr 28, 2005 | 05:46 PM
Zetec Andy's Avatar
Zetec Andy
I had the same problem on my laguna, soon after it spilt its guts all over the road and i lost all drive gears its still sat here on the drive!
Old Apr 28, 2005 | 05:55 PM
dave green's Avatar
dave green
Sounds like the oil is low.
Dave
Old Apr 28, 2005 | 06:12 PM
Spax's Avatar
Spax
not the reply he was after lol
Old Apr 28, 2005 | 07:11 PM
Jon ERST S2
sounds good I've never worked on an auto box. Is the oil easy to top up (i.e from the engine bay?)
Dave
Old Apr 29, 2005 | 07:36 AM
nthorpey's Avatar
nthorpey
Easy to top up if you have a long funnel .
Make sure you check the box oil level with the engine running.
The dipstick is on the right hand side and is a short yellow thing
Old Apr 29, 2005 | 07:59 AM
Jon ERST S2
Top advice I'll give it a go tommorow.
Fingers crossed.
Old Apr 29, 2005 | 08:49 AM
gearboxman's Avatar
gearboxman
It does indeed sound like low oil level, unlike Andy's Laguna, which has the forward clutch piston split.
With the Mondeo, oil level should be checked in Neutral (engine running), as the cooler circuit does not run in Park (unless it has a valve-body mod )
Old Apr 29, 2005 | 05:18 PM
Jon ERST S2
cool - cheers bernie. Any particular oil to use in it?
Old Apr 30, 2005 | 07:28 AM
Jon ERST S2
bttt for what oil to use to top up?
Old Apr 30, 2005 | 09:04 AM
gearboxman's Avatar
gearboxman
Automatic transmission fluid, Dexron 2 or Dexron 3.
Old May 1, 2005 | 08:45 AM
Jon ERST S2
cheers
Old May 2, 2005 | 10:02 AM
Jon ERST S2
right checked and its definetly low. Can I pour in through the dip stick tube? It's quite wide with say a piece of hose and funnel?
Also on the dipstick it says check hot running in Park (I tried first in neutral) and it was low. It was still low in park.
cheers
Old May 2, 2005 | 05:53 PM
Jon ERST S2
All Sorted. Cheers
mk22door
49
Mar 26, 2022 07:15 AM
Chas
Sep 21, 2015 08:57 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
kosienutter
31
Aug 22, 2015 09:55 AM
A.t.p
Aug 15, 2015 11:37 AM
