Domestic Drainage Question.......
Old Apr 27, 2005 | 07:06 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Default Domestic Drainage Question.......
Regarding a Washing Machine Waste Pipe.......
Is there a guideline for the amount of 'Fall' that should be on a pipe for this purpose?
Or is a 'Slight' fall enough? (e.g. 2"-3" over a 2 Metre length?)
Old Apr 27, 2005 | 07:22 PM
Šhatter Box's Avatar
Šhatter Box
just make sure it dont go straight down or thw waste water will go back in the washer!!! have u got a downpipe with the swan neck or a spigot under the sink ? just make sure it goes up before it goes back down
Old Apr 27, 2005 | 07:31 PM
Christian and Beccy
#1 in Spelling Club
This is a new installation so I havent got anything yet, so I can do it however. All I know at the moment is that I need a length of pipe to run horizontally under the floor and I haven't got alot of room, so can't get alot of fall on it.
Old Apr 27, 2005 | 07:36 PM
Šhatter Box
trouble with extension pipes it puts the drain pump under alot of strain
Old Apr 27, 2005 | 07:50 PM
Christian and Beccy
#1 in Spelling Club
Im not sure if I have explained fully enough.
Where the Washing machine is going, the obvious way is to fit a 'Stand-Pipe' behind the machine, then round a Swan-Neck type bend before heading off towards the Main House Drain, which is about 2 Metres away.
I havent really thought about how the machine will connect to the Drain Pipe yet, not really worried about that at this stage.
Most people would probably take the pipe out through the wall and along the outside wall into the drain. However, I dont really want the pipe on the outside wall, so I want to run it under the floor. However, there isnt alot of height available under the floor where the pipe is going, so I need to chase a channel out for the pipe to run in. Thats why I need to know about Fall on the pipe as the more fall that is needed, the deeper my Channel will need to be.
Make more sense now?
Old Apr 27, 2005 | 07:52 PM
MK5RST's Avatar
MK5RST
Cristain, post some pics make, im a drainage engineer
Old Apr 27, 2005 | 07:57 PM
Christian and Beccy
#1 in Spelling Club
Its hard to post pics, cos there really isnt anything there yet!!
Its like a blank canvas.
Starting at the start then, assuming there is no facility at all for the waste outlet for the washing machine, what the best way to do it??
1. Vertical Open Stand Pipe that you simply loosely put the hose off the Washing Machine into?
2. Vertical Stand Pipe that is closed off with some kind of proper connector for the Washing Machine Hose??
or some other way?
Old Apr 27, 2005 | 10:31 PM
Iain Mac's Avatar
Iain Mac
Mine has a vertical pipe behind the machine that's maybe 18-24 inches tall and the drain pipe just pops into the top of that.
Below floor level I'm almost certain there is a u-bend thing to stop the drain smells coming up the pipe.
As for fall, I'd guess that an inch or so per metre run will be enough. Too much is as bad as not enough.
Dave2302
Mar 26, 2010 07:17 PM
Neil S
Oct 16, 2009 06:52 PM
Gatecrasher
17
Jan 21, 2008 06:35 PM
Christian and Beccy
Apr 5, 2005 01:13 PM
