Wheel bolts for RS7 spokes?
What wheel bolts are used to fit the RS7's to an ERST?
Tried Fords and RSR but both no help.
I can remember seeing a post on here ages ago but cant find it, can anyone help?
Paul
Paul
I assume the Wheel Bolt holes on those are large? If so, the nuts you need are known as Ford Ghia nuts. I can probably get them, but only order from my supplier periodically. Are you in a hurry?
Yeah the holes are quite large.
Gonna try another local place tom and see how I get on.
I can remember someone saying a while back about cutting the tapered sleeve off the wheel nuts that came with the wheels and fitting them to other Ford wheel bolts?
Cheers for the help Christian, I'll see how I get on tom and let you know.
Paul
Paul
there the same ones u need to fit to the mondeo 16" onces i got mine from rally design they do next day delivery
http://www.raldes.co.uk/
I however want to change to one of Christians stud conversions
There nothing wrong with cutting off the collets off the ford wheels nuts it the same collect that you had to buy from fords but is no longer avab. so just cut the collect off the nuts that come with the RS`7s and use the standerd RST wheel bolts with collect and it would be fine.Thats the way ford sold the alloys you had to buy the collects as well so it`s not a bodge job cutting them off
So theres no chance of anything going wrong
Used collects on loads of diffent mk3/4 escorts never had a prob
Paul If you get stuck.
www.speedshack.co.uk
Can sell you some bolts with the larger washers on. I had to use them when I had the Brooklands wheels on my old Escort. They were Ł1.50 each IIRC.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
